michelleadams
May 9, 2013
Using US map shapes
I'm trying to create a graph of power plant production in the US.  I have the production data, and the lat/long of all the plants, but can't seem to get it to graph correctly in graph builder. I read the help files, and tried using the background maps option, the map shape area of graph builder, even played around with defining map roles in the column properties, and can’t get any of it to work.  Do the lat/long data columns need to be in a specific format?  Thanks!
reeza
Jun 23, 2011
Re: Using US map shapes
What does your lat long data look like?
michelleadams
May 9, 2013
six different integer columns for latitude degrees, latitude minutes, latitude seconds, longitude degrees, longitude minutes, longitude seconds.
reeza
Jun 23, 2011
convert it to two columns I believe but some sample data would help as well.
michelleadams
May 9, 2013
LATITUDE_DEGREESLATITUDE_MINUTESLATITUDE_SECONDSLONGITUDE_DEGREESLONGITUDE_MINUTESLONGITUDE_SECONDS
378521191522
3335261112038
luisgaliano
May 17, 2013
Michelle,
As Reeza said, convert your data to two columns (I use decimal notation, not deg/min/sec, I'm not sure if JMP takes deg/min/sec, but with the columns as you have them delineated you can easily write a formula column to calculate decimal lat/long  ( Dec Degree = degree+Min/60 + sec/3600). Then you can use it in Graph builder with whichever background map/shape you prefer.
