BookmarkSubscribeRSS Feed
Using Simulate [JMP Pro] in a Script
shoffmeister
Mar 27, 2015
I would like to use the simulation-feature of JMP Pro to make a power analysis for multiple different scenarios. Is there a way to start the simulation via script, as it would be a lot of work to go through the process manually.
Thanks in advance,
Sebastian
ian_jmp
Jun 23, 2011
Solution
This shows the basic idea (building on one of the examples in the documentation for a permutation test):
dt = Open( "$SAMPLE_DATA/Analgesics.jmp" );
dt << 	New Column( "pain shuffled",
							Numeric,
							"Continuous",
							Format( "Fixed Dec", 4, 2 ),
							Formula( Col Stored Value( :pain, Col Shuffle() ) )
ow = dt << Oneway( Y( :pain ), X( :drug ), Means( 1 ), Mean Diamonds( 1 ) );
Report(ow)[TableBox(2)] << simulate(1000, 999, Out(:pain), In(:pain shuffled));
ian_jmp
Jun 23, 2011
Solution
							Numeric,
							"Continuous",
shoffmeister
Mar 27, 2015
Thanks a lot Ian!
ghartel
Mar 5, 2017
I'm trying this with the partition platform, but the partition platform REDO script adds in an "Initial Splits" option with the fit from the original run.  The simulations don't re-run the whole fit with all the vriables, but only with the variables that came from the original model.  This affects the results from the simulation - ie they are totally wrong.  Is there some way around that?
Here is the code I'm using:
dt = Open( "$SAMPLE_DATA/Diabetes.jmp" );
dt << new column("Permuted Y Binary",character, formula(Col Stored Value( :Y Binary, Col Shuffle() )));
dt << run formulas;
Pa = Partition(
 Y( :Y Binary ),
 X(
 :Age,
 :Gender,
 :BMI,
 :BP,
 :Total Cholesterol,
 :LDL,
 :HDL,
 :TCH,
 :LTG,
 :Glucose
 Informative Missing( 1 ),
 ROC Curve( 1 ),
 K Fold Crossvalidation( 5 ),
 go
Pa << finish;
Report( Pa )["Receiver Operating Characteristic"][Table Box(1)] << Simulate(100, Out(:Y Binary), In(:Permuted Y Binary));
