It’s World Statistics Day! To honor the theme of the day, the JMP User Community is having conversations about the importance of trust in statistics and data. And we want to hear from you! Tell us the steps you take to ensure that your data is trustworthy.
nqj
nqj
Using Pat Match within Loop
I'm trying to write a program to take an input string, find a key word within the full string, and create a new column with just the abbreviation. The script should iterate over all the rows of a single column. My code throws an error and I believe it is the syntax of my loop but can't seem to figure out where the error is. Here is what I have:
For Each Row(
	:prodFam = If(
		Pat Match(:prodGroup, "aleutian"),
		"ALEUTIAN",
		Pat Match(:prodGroup, "ari"),
		"ARI",
		Pat Match(:prodGroup, "blue"),
		"BLUE RIDGE",
and the loop continues. Any help is greatly appreciated, thanks!
Re: Using Pat Match within Loop
You need a Boolean response for your If() function to work. That way is how the result of Contains() will be interpreted as I have already explained.
nqj
nqj
So I've realized that once you create a reference to a column, you no longer use colons to state that it is a column name. However, my script now runs without populating the table with the abbreviations. Am I still missing something? Thanks!
First of all, if this code is not part of a larger script, then you could enter as a column formula. The argument in the For Each Row() function is the same as the column formula.
Second, while character string patterns are very useful, I I think that you could use Contains( test string, target string ) in this case.You are not looking for a pattern but a literal string (word). Contains() return the location if found or zero if not found. JMP interprets zero as false and non-zero as true, so your logic implemented with the If() functions stands as it is.
nqj
nqj
the problem with using the Contains() function is that it returns a numeric value when I really just need a true or false boolean value. I suppose I could use the value it returns to index a substring, but in the end that seems like more lines of code for something that could be done using pat match, does it not? Thanks for the reply!
David_Burnham
As you say the Contains function returns a numeric value (the position where the item is contained). However, you can treat the value as boolean: 0=false, otherwise true, so you can write code that treats the Contains function as boolean:
If (Contains(...),
    // do something
-Dave
