BookmarkSubscribe
kbjacket
Community Member
Using JMP with Webservice
Hello!
I am interested in setting JMP up for use with a webservice, such as SOAP. I have use JMP quite a bit, but I am very much a beginner with webservices. Does anyone have any suggestions?
Thanks!
David_Burnham
JMP exposes its functionality via OLE automation which means that you can access JMP functionality via languages such as Visual Basic or C#.
If you look in the installation directory of JMP you will find a PDF document called Automation Reference that defines the object model and method calls.  There is also a directory containing sample code.
You say that you are a beginner with web services -so your first step is to learn how to implement a web service using your preferred .NET language.
You can then simply insert JMP object method calls into your web service definition.
-Dave
-Dave
