BookmarkSubscribeRSS Feed
brianq_
Jun 23, 2011
Using GetRowsWhere
I'm trying to use the "Get Rows Where ()" function, but I am having difficulty getting the script to work without hard coding the column names.
For example the following 2 lines of code work:
my_list = dt<my_list = dt<
However I do not want to hardcode the column name and I want to use code similar to the following:
target_col = Column(dt,"DataSetId");
my_list = dt<
I've tried various combinations of things including (based mostly on complete guesses), but haven't been able to come up with a working solution. Any help with this would be appreciated. Thanks!
Re: Using GetRowsWhere
Try this:
In the line
my_list = dt<
replace target_col with target_col[]
brianq_
Jun 23, 2011
Thanks a ton! Works like a charm! =)
Jeff_Perkinson
Community Manager
Jun 23, 2011
The As Column() function may help to make it a little clearer what's going on.
my_list = dt<
Jeff
-Jeff
