BookmarkSubscribeRSS Feed
robot
Feb 27, 2012
Using Column Lists
I would like to grab a list of column names, and then use that list to subset a data table.  An example script is below; I get an error because it seems that JMP does not recognize the list as column names.  What is the correct syntax to use here?  I am using JMP11.  Thanks!
// Example.
bigClass = Open( "$SAMPLE_DATA/Big Class.jmp" );
names = bigClass << Get Column Names( Numeric );
sub = bigClass << Subset( Columns( names ) );
robot
Feb 27, 2012
Re: Using Column Lists
Never mind.  Got it.
// Example.
sub = bigClass << Subset( Columns( Eval( names ) ) );
