User chooses rows to subset?
hacketkm
Sep 14, 2012
I would like to allow the user to select which rows to subset based on the values in one of the columns. They need to be able to select more than one value. I'm having trouble with selecting the rows based on which values the user chooses. :Generic Description is made up of character values, not numbers.
The code I am working with looks like this:
Summarize( GD = By( Column( dt, "Generic Description")));
nw = New Window( "Choose the Generic Descriptions to analyze",
     hb = HList Box(
          Panel Box( "Select the GDs",
          select1 = List Box(
               GD))
     Button Box( "OK",
          nw << Close Window;
          dt << Select Where( :Generic Description == select1 << Get Selected);
          dt << Subset(( Selected Rows), Output Table Name( "Selected GDs")))
Can anyone help me out?
pmroz
Jun 23, 2011
Solution
The problem is that the results from "Get Selected" are a list.  You can't use the == operator in this context.  You can use contains to get the desired result:
dt = Current Data Table();
Summarize( GD = By( Column( dt, "Generic Description" ) ) );
    hb = H List Box(
            select1 = List Box( GD )
    Button Box( "OK",
        select_list = select1 << Get Selected;
        dt << Select Where( contains(select_list, :Generic Description ));
        dt << Subset( (Selected Rows), Output Table Name( "Selected GDs" ) );
        nw << Close Window;
pmroz
Jun 23, 2011
Solution
    hb = H List Box(
    Button Box( "OK",
        nw << Close Window;
hacketkm
Sep 14, 2012
Thank you very much! This works.
