BookmarkSubscribeRSS Feed
PS_Ato
Community Trekker
Jun 26, 2017
Use of "drag&drop" method for exchange of graph labeling for virually joined columns failed
Dear all,
I used the link-ID and reference-ID to combine tables and to create graphs and variability charts with these virtually joined column names. So far, everything worked fine.
But, I don't manage to replace the position of one collumn name e.g. s-Pd [ID 2\Leg 1] with the other Pd bath [ID1\Leg 1]. This is possible with conventional column names. Instead, I get the following
JMP Alert: "Error: Details written to the log"
Now, I struggled to insert a copy of the graph nor a snipped graph to illustrate my question. Therefore please find a part of the script:
Variability Chart(
Y( :Name( "Total Energy (mJ)" ) ),
X(
Referenced Column(
"s-Pd_set [nm][ID 2\Leg 1]",
Reference(
Column( :Leg 1 ),
Reference(
Column( :ID 2 ),
Reference( Column( :Name( "s-Pd_set [nm]" ) ) )
Referenced Column(
"Pd bath[ID 1\Leg 1]",
Reference(
Column( :Leg 1 ),
Reference(
Column( :ID 1 ),
Reference( Column( :Pd bath ) )
:Activation
I hope someone has an idea. Many thanks.
Petra
