bernie426
Use Combo box to select/deselect rows
I like to set up a combo box that can help me to select/deselect/exclude/hide some rows in some specific row,
Can any help out on my script below?
Many Thanks,
dt=Current Data table();
MRB_List={"Bin1", "Bin2", "Bin3", "Bin4", "Bin5"};
Prod_List={"Binned"};
New Window("Production & MRB Filter",Outline Box("Production Selection/Exclusion"),
  cb=Combo Box ({"MRB","Prodction Goods"},
  selection = cb << getselected()
  << select  where( Contains( MRB_List, :BinClass_ )),//<< Enable <<Exclude <<Hide
  << select  where( Contains( Prod_List, :Category ))),//<< Enable <<Exclude <<Hide
ian_jmp
Level X
Re: Use Combo box to select/deselect rows
Not sure I completely understand what you want. But this example should help with the 'mechanics' of the 'ComboBox()':
// Make a table
n = 30;
MRB_List={"Bin1", "Bin2", "Bin3", "Bin4", "Bin5", , "Bin6", , "Bin7", , "Bin8", , "Bin9", , "Bin10"};
MRBVals = {};
for(i=1, i<=n, i++, InsertInto(MRBVals, MRB_List[RandomInteger(1, NItems(MRB_List))]));
dt = NewTable("Bin Data", NewColumn("BinClass_", Character, Nominal, Values(MRBVals)));
// Make the UI
New Window("MRB Filter",Outline Box("Bin Selection/Exclusion"), cb = Combo Box (MRB_List, cbScript));
cbScript =
Expr(
   myBin = cb << getselected;
   dt << clearRowStates;
   dt << selectWhere(:BinClass_ == myBin ) << Enable <<Exclude <<Hide;
ian_jmp
Level X
// Make a table
n = 30;
MRBVals = {};
// Make the UI
cbScript =
Expr(
bernie426
Thanks Ian,
You are very close to what I want. However, one step further on my question
If the column I like to select and exclude contains information {Bin1, Bin2....Bin10, Run#1, Run#2....Run#100 Recheck} and I like to select and exclude as rows that are related to Bin, Run#, and Recheck. Then, the script below does not work out, seems like the "% " cannot work this way.
Is there any alternative way?
Regards,
dt=curent data table();
MRB_List={"Bin%", "Run%", "Recheck%"};
cbScript =
Expr(
ian_jmp
Level X
So, if I have understood correctly, you need to select multiple levels from the same column. 'ComboBox()' forces you to make one selection, but you can try 'ListBox()' instead (use the SHIFT or CONTROL keys as you click the items in the list):
// Make a table
n = 30;
MRB_List = {"Bin1", "Bin2", "Bin3", "Bin4", "Bin5", , "Bin6", , "Bin7", , "Bin8", , "Bin9", , "Bin10"};
MRBVals = {};
For( i = 1, i <= n, i++,
Insert Into( MRBVals, MRB_List[Random Integer( 1, N Items( MRB_List ) )] )
dt = New Table( "Bin Data", New Column( "BinClass_", Character, Nominal, Values( MRBVals ) ) );
// Make the UI
New Window( "MRB Filter", Outline Box( "Bin Selection/Exclusion" ), lb = List Box( MRB_List, cbScript ) );
cbScript = Expr(
myBins = lb << getselected;
dt << selectWhere( Contains(myBins, :BinClass_ )) << Enable << Exclude << Hide;
ram
ram
Is it possible to select multiple in combox? e.g Bin1 and Bin4.
Thanks
Ran
