Uplift Modeling in JMP Pro 13
Laurents_Mohr
Apr 12, 2017
I have JMP Pro 13 and supposedly there is the Uplift Modeling function under Analyze > Consumer Research, as described in the online documentation. But it's not there and I couldn't find it anywhere?! I am using a Mac.
Does anyone know whats going on?
Best,
Laurents
Laurents_Mohr
Apr 12, 2017
Solution
Thank you Jeff,
It was marked hidden in the view menu > customize menu screen.
Unhiding helped :)
Jeff_Perkinson
Community Manager
Jun 23, 2011
I can't find any common reason why the menu wouldn't appear.
Can you go to JMP-> About JMP and post a screen capture of that window?
You might also want to contact Tech Support to see if they've got any suggestions.
-Jeff
Laurents_Mohr
Apr 12, 2017
Solution
Thank you Jeff,
Unhiding helped :)
