PS_Ato
Update to JMP 15 (64bit) -> JSL Scripts are not working anymore, that import data from a Access data base (32 bit ODBC driver Manager)
Dear all,
Any advice would be appreciated. I saw some older discussions discribing similar issues with 64bit JMP(12) and 32 bit ODBC Driver - but no recent discussions related to JMP 15.
Looking for your comments and best regards,
Petra
Re: Update to JMP 15 (64bit) -> JSL Scripts are not working anymore, that import data from a Access data base (32 bit ODBC driver Manager)
Yes, you must update your ODBC drivers with their 64-bit version to work with JMP 15, which is only 64-bit.
PS_Ato
Thank you. - Feeling a bit sorry, because this ODBC Driver update has a minor priority for our IT department right now - and the roll-out of JMP 15 for the whole company was stopped now due to this issue.
