BookmarkSubscribeRSS Feed
rleeper
Update table inside for loop
I am trying to update a table inside a for loop.  When the next iteration comes in I am using an If statement to open the same data source under a different name and then update the first table.  The problem is Jmp keeps adding a number to the first table's name so rather than getting 8 updates, I get 8 separate tables.  NR is my number of records that needs pulled and added to each table.  V is the record I want to obtain and add to the existing table.
For( i = 1, i <= NR, i++,
V = Vlo[i];
Vlo_Temp = Open Database(
"DSN=EZ Mes;Description=EZ;UID=;Trusted_Connection=Yes;APP=JMP;WSID=RLEEPER;DATABASE=EZ_DB_LOADER",
"SELECT * FROM dbo.tbl_NVR WHERE NV_VALUETYPE = 'DateTime' AND UID_NOW = '" || V || "'",
"Vlo_Temp"
If( i > 1,
V_Temp = Open Database(
"V_Temp"
Vlo_Temp = Vlo_Temp << Update( With( Data Table( "V_Temp" ) ), Output Table Name ("Vlo_Temp") );
V_Temp << Close Window;
Help?
pmroz
Re: Update table inside for loop
Can you just read in the table dbo.tbl_NVR all at once without looping over it?
If that is not possible then try closing the table using
close(v_temp, nosave);
instead of using << close window.
wiebepo
Unless there is more to it, I agree with PMroz. I suspect a for loop is not necessary. Consider the following code, which should get all the values desired in one query.
"SELECT * FROM dbo.tbl_NVR WHERE NV_VALUETYPE = 'DateTime' AND UID_NOW IN ('" || concatitems(vlo[1::NR],"', '") || "')",
"Vlo_Temp"
rleeper
Wiebepo,
Thank you for the interesting code.  I didn't know I could do a concatitems inside a SQL query.
I fixed my problem by removing the first query from the loop and running the next query without the If statement, then everything worked.
