samir
Update script-analysis and graphs based on inputs from "New Window"
I am triying to write a script that interactively is re-run based on varying values provided by a "New window".
Here is the scheme:
1/ I open a window that has a button ("Select Master File").
2/ When I click on this button, a "pick File" is launched, and I select a file
3/ based on the content of the selected file, I should run a script and generate graphs
Here are my questions:
1/ How to make sur each time I select a new file, the whole script is re-run and graphs are updated ?
2/ How to get the graphs embedded in the "New window" where I select the file ?
3/ The script I have to run is rather long and several graphs have to be generated. Is there a way to call this script without putting all the code in the "New window" code ? (like calling a function or so,...)
Thanks a lot.
Find below a simplified version of the code (with 2 files attached to test the code):
// Collect location of the Master file and the data...
New Window( "Window Controls",
	Lineup Box( N Col( 1 ), Spacing( 3 ),
		Panel Box( "1/ Select location of Data...", Button Box( "Select Data", Folder = Pick Directory( "Please pick a folder", ShowFiles ) ) ),
		Panel Box( "2/ Select Data Master File...", g1=Button Box( "Select Master File", MasterFile = Pick File()
		Col List Box( all ); //g1 << updateWindow;
MasterTable = Open( MasterFile );
Lots = Column( MasterTable, "Lot" ) << GetAsMatrix;
Factors = Column( MasterTable, "Factor" ) << GetAsMatrix;
x = Factors * [10, 50, 90];
y = Factors * [10, 90, 10];
New Window( "Poly Seg Example", g = Graph Box( Poly Seg( x, y ) ) );
pmroz
Re: Update script-analysis and graphs based on inputs from "New Window"
Here's one way to save the graphs as an expression, and then use it later in the new window.
dt = open("$sample_data\Big Class.jmp");
g1_expr = expr(
	gb1 = dt << Graph Builder(Show Control Panel( 0 ),
		Variables( X( :weight ), Y( :height ), Overlay( :sex ) ),
		Elements( Points( X, Y, Legend( 6 ) ) )
g2_expr = expr(
	gb2 = dt << Graph Builder(Show Control Panel( 0 ),
		Variables( X( :age ) ),
		Elements( Pie( X, Legend( 3 ), Label( "Label by Value" ) ) ),
		SendToReport( Dispatch( {}, "Y title", TextEditBox, {Set Wrap( 2 )} ) )
nw = new window("Sample Graphs",
	hlistbox(
		g1_expr,
		g2_expr
samir
That solves perfectly the item 3/.
Many thanks !!!!!!!!!
Any idea on how to solve 1/ and 2/ ?
