GabeM27
Update multiple cells based on another cells value
When I execute the following it updates other cells that I did not create an if for.
How can just update the ones I am calling out in the for row and if function?
dt << New Column( "NewAge", Character, Continuous );
dt << New Column( "NewAge2", Character, Continuous );
dt << New Column( "NewAge3", Character, Continuous );
For Each Row(
	If(
		dt:Age == 14,
			dt:NewAge = "Blah";
			dt:NewAge2 = "Blah2";
			dt:NewAge3 = "Blah3";
			dt:Age == 15;,
		dt:NewAge = "yay";
		dt:NewAge2 = "yay2";
		dt:NewAge3 = "yay3";
		dt:Age == 16;,
			dt:NewAge = "yo";
			dt:NewAge2 = "yo2";
			dt:NewAge3 = "yo3";
	0
Re: Update multiple cells based on another cells value
  1. Your new columns are Character columns, therefore they can only have a Nominal Modeling Type.
  2. You were using a semicolon ";" at the end of an IF() comparison, rather than a comma ",".  The scructure of an IF() function is:
    IF( comparison,
         // If True
         icalculation;
         calculation;
         // If not true
         comparison,
         // if True
         calculation;
         calculation;
         // Else
         calculation;
    Here is a rework of your code
  3. Names Default To Here( 1 );
    dt << New Column( "NewAge", Character );
    dt << New Column( "NewAge2", Character );
    dt << New Column( "NewAge3", Character );
    Current Data Table( dt );
    For Each Row(
    	If(
    		dt:Age == 14,
    			dt:NewAge = "Blah";
    			dt:NewAge3 = "Blah3";,
    		dt:Age == 15,
    			dt:NewAge = "yay";
    			dt:NewAge3 = "yay3";,
    		dt:Age == 16,
    			dt:NewAge = "yo";
    			dt:NewAge2 = "yo2";
    			dt:NewAge3 = "yo3";,
    		"0"
