BookmarkSubscribeRSS Feed
Hegedus
Update a text field in a modal window
I am trying to create a window that opens at the start of the script.  I want the user to open three files for import and then set some input parameters before the 100+ graphs are created.
I would like to have buttons with the filename requested which executes a pick file function.  I then parse the full file path to just the filename and I would like to show it in a text box next to the button.  If I create a text box which has it's contents defined by a text variable and try to update that variable via the button script, it does not work.  The text in the text box is not updated.  If I include show(filename), the log window shows that the variable has been updated.
What message should I send to the text box to update the text in it?
DFilename = "";
New Window( "Set Scaling Factors",
  <<Modal,
  V List Box(
  Lineup Box( N Col( 2 ),
  Button Box(
     "pick",
     (DFile = Pick File( "Select the Design File (Excel)" ) ;
     DFileName =  Words( DFile, "/" ) ;
     DFileName =DFileName[(N Items(DfileName))];
  DF=Text Box( DFilename ),
  H List Box( Button Box( "OK", ), Button Box( "Cancel", stopflag = 1 ) )
show(Dfilename);
ms
Super User ms
Re: Update a text field in a modal window
The message should be part of the button box script.
Button Box("pick",
                DFile = Pick File("Select the Design File (Excel)");
                DFileName = Words(DFile, "/");
                DFileName = DFileName[N Items(DfileName)];
                DF << set text(DFilename);
