DSA
DSA
Unexpected behaviour with capability analysis in control chart builder
Dear JMP community,
after getting a workaround for my last issue with the capability analysis in the control chart builder i are now experiencing other strange behaviours.
I have a control chart building with USL, Target and LSL showing (coming from column properties) and a column switcher so it is possible to browse through all parameters (some have all specs, some only LSL and Target, some does not have any specs).
But when i fx remove a spec, or exclude a datapoint the capability analysis does sometimes vanish. Even if I click "Show capability" it does not show up again.
If I select another column in the switcher the capability analysis comes back, and if I then reselect the old column it is still there showing.
Are someone else experiencing this?
Is this another bug in the system?
Thanks in advance,
Daniel
