BookmarkSubscribe
saitcopuroglu
Community Trekker
Unable to reproduce Date/Time axis settings and annotation text placement with jsl
Manually produced;
Scriptly produced
Re: Unable to reproduce Date/Time axis settings and annotation text placement with jsl
Can you clarify where the second graph came from? Is it the result of selecting "Save Script to Script Window" on the first graph and then running the resulting script, or an attempt at reproducing the first graph manually using hand-written JSL?
saitcopuroglu
Community Trekker
The first one, produce manually, copy script, paste it to a new script window combine it with the source jsl also copied, glue them.
Mandy_JMP
Any chance you could share a sample of your data and the JSL script?
saitcopuroglu
Community Trekker
Sure, hence confidential data pls let me know an address where I can send to
Mandy_JMP
sent a message
