BookmarkSubscribeRSS Feed
kozak88
Community Member
Unable to make correlation analysis with list input
Hi all, I am having a problem with the Multivariate command.
Why doesn't this work:
numericList = {Column("age"), Column("height"), Column("weight")};
cor = Multivariate(
  Y( numericList ),
  Estimation Method( "Row-wise" ),
  Scatterplot Matrix(
  Density Ellipses( 1 ),
  Shaded Ellipses( 0 ),
  Ellipse Color( 3 )
  Pairwise Correlations( 1 )
and this does:
cor =Multivariate(
Y( :age, :height, :weight ),
Scatterplot Matrix(
Ellipse Color( 3 )
and what do I have to do to fix it? Ofcourse i would like the command to be dynamic therefore i want the first option to work.
Thanks!
Re: Unable to make correlation analysis with list input
All you need to do is to evaluate the list
numericList = {Column( "age" ), Column( "height" ), Column( "weight" )};
cor = Multivariate(
Y( Eval List( numericList ) ),
Scatterplot Matrix( Density Ellipses( 1 ), Shaded Ellipses( 0 ), Ellipse Color( 3 ) ),
cor = Multivariate(
