Sburel
Unable to load a list of columns to conduct a Contingency analysis
hello,
I want to run a contingency analysis. I have a list of column names (annotationls) to use for Y. Unfortunately with the (wrong) synthax I'm using only the first column name is read and the rest is ignored.
The rest of the script is working well.
Any suggestions to correct the synthax would be appreciated.
thanks
Sebastien
annotationls = {Name("N(BDNF signaling pathway)"), Name("N(Cross-presentation of particulate exogenous antigens (phagosomes))"), Name("N(Immune system)"), Name("N(Inflammasomes)"), Name("N(Inflammatory response pathway)"), Name("N(Innate immune system)"), Name("N(Integrin alpha-2b beta-3 signaling)"), Name("N(Integrin beta-2 pathway)"), Name("N(Integrin beta-4 pathway)"), Name("N(Integrin beta-5 pathway)"), Name("N(Integrin cell surface interactions)"), Name("N(Integrin family cell surface interactions)"), Name("N(Integrin signaling pathway)"), Name("N(Integrin-linked kinase signaling)"), Name("N(Integrin-mediated cell adhesion)")};
modulals = {Name("Modulation - Abs(Fold change)> 1.5 & LogWorth Adj pvalue> 0.01")};
d={"test_article"};
u={"specimen_material_type"};
DGEsum = Data Table( "summary of DGE" );
enrich=DGEsum<<contingency	(
	Y( column(annotationls)),
	X(column(modulals)),
	by(column(d),column(u)),
	Contingency Table( 0 ),
	mosaic plot(0),
	Tests( 1 ),
enrich<<make into combined table("test");
Report( enrich[1] )[Outline Box( "Tests" )][Table Box( 3 )] <<
Make Combined Data Table;
Report( enrich[1] ) << Close Window;
Re: Unable to load a list of columns to conduct a Contingency analysis
You will want to use the Eval() function to expand the input lists.
names default to here(1);
d={"test_article"};
byList = d||u;
	Y( eval(annotationls)),
	X(eval(modulals)),
	by(eval(byList),
	mosaic plot(0),
	Tests( 1 ),
d={"test_article"};
byList = d||u;
	X(eval(modulals)),
	by(eval(byList),
	mosaic plot(0),
	Tests( 1 ),
