Sburel
Unable to launch Bioassay addin using JSL
I'm trying to write a script which would conclude with launching the Bioassay (V2) addin.
Based on reply from @pmroz way back then, I would think the following code should launch it
include("$ADDIN_HOME(com.jmp.bioassay)/Dialog Display.jsl")
However, nothing happens.
The addin contains several scripts and I assume one should be refereed but it's not clear  which one(s).
Any insight would be appreciated
Best,
Sebastien
pmroz
Re: Unable to launch Bioassay addin using JSL
If the addin is run via a menu command, take a look at what is executed.
Click on View > Customize > Menus and Toolbars
Click on the menu option for the addin in question.
Check the Action section for how it's run.
pmroz
Sburel
Thanks for the tips. It's what I needed
