burakbagdatli
UI elements have wrong shapes
I loaded up JMP and saw that a number of JMP UI elements have the wrong height. It's like every vertical padding got out of control.
The best I can explain this is with a screenshot so I'm attaching one:
I uninstalled 14.0, reinstalled 14.1 and the problem persists. I uninstalled 14.1 deleted my profile folder under user\appdata\etc... reinstalled, the problem persists. I did the previous steps, restarted computer and reinstalled afterwards, the problem persists. No other application on my computer has this problem. Graphical settings are set to 100% with no weird custom settings. I'm on a Windows 10 device.
Has anyone seen anything like this before and know the fix?
What we see of the real world is not the unvarnished real world but a model of the real world, constructed so it is useful for dealing with the real world. —Richard Dawkins
Re: UI elements have wrong shapes
I would send this to Technical Support at support@jmp.com to see if they have had other reports like this.
Chris
Chris Kirchberg
Principal Systems Engineer, Life Sciences - JMP Global Technical Enablement
SAS Institute, Inc. - Denver, CO
Tel: +1-919-531-9927 ▪ Mobile: +1-303-378-7419 ▪ E-mail: chris.kirchberg@jmp.com
JMP – A Division of SAS Institute | www.jmp.com
