Theresa
Two percentage do comparison, if one column <another column, build a new column name with status fill in"Yes", otherwise "No"
This is the function i need and below script is workable when i test, but when i change the column name it do not work, pls check the pic: My column"Target Progress" and "Actual Progress" are the percentage this is a different with big class. How to revise the script?
workable scripts:
dt << New Column( "status", "Character", "Nominal" );
:status << Set Values( {"yes", "no"}[(:height << Get As Matrix) <= (:weight << Get As Matrix)] );
Failed scripts: "Target Progress" and "Actual Progress" are the percentage.
	{"yes", "no"}[(:Actual Progress << Get As Matrix) >= (:Target Progress << Get As Matrix)]
vince_faller
Re: Two percentage do comparison, if one column <another column, build a new column name with status fill in"Yes", otherwise "No"
My guess is because the matrix you're giving is giving a zero.
JMP indexing starts at 1 not 0.
Try this.
:status << Set Values({"yes", "no"}[((:Actual Progress << Get As Matrix) >= :Target Progress << Get As Matrix))+1]);
You should check that you're getting the right values for yes and no, you might want to swap the yes and no.
But really I would just set them explicitly and use value labels.
dt << new Column("Status", <<Set Each Value(:height <= :weight),
	Value Labels({0 = "No", 1 = "Yes"}),
	Use Value Labels(1)
Vince Faller - Predictum
vince_faller
Try this.
	Use Value Labels(1)
Theresa
Final use this works. Thank you so much.
dt = Current Data Table();
dt << New Column( "Actual Progress.",
	"Numeric",
	formula( If( :Target Complete >= :Actual Progress, "Yes", "No" ) )
