Agustin
Trying to use Remove(source, {items})
I'm trying to remove 2 items from a list but I'm getting this error
"index must be number or list of numbers at row 1 in access or evaluation of 'List' , {/*###*/lst2}"
lst = As List((Associative Array( dt1:Name << get values ) << Get Keys))
lst2 = As List( {"NTC","PC"})
Remove( lst, {lst2})
lst2 = As List( {"Pete","Clare"})
Remove( lst, lst2)
I've tried both there options and they both return an error. Where am I going wrong?
Re: Trying to use Remove(source, {items})
Error message is quite clear here, you need to have number or list of number which you use for deletion, not a list of strings
Without knowing more about what you are trying to do, you could for example use Filter Each or Associative Array
lst = Associative Array(dt:Name << get values);
lst2 = Associative Array({"KATIE", "BARBARA"});
show(Contains(lst, "KATIE"));
lst << Remove(lst2);
lst = lst << get keys;
Work with Associative Arrays (jmp.com)
