jmit
Nov 2, 2016
Try to mimic Excel with JMP - connected lines plots
Hello, I am a bit new in JMP and I would like to plot X-Y parameters with two groups of data embedded. I attached in the zip an example of data table in JMP and excel as well. thx for your help! /JM
Jun 22, 2012
Solution
Re: Try to mimic Excel with JMP - connected lines plots
All that has to be done is to use Graph Builder.  Drag your X and Y columns to their appropriate box, right click on the graph and remove the smoother.  Then change the points to line. Drag the Samples ID to the overlay drop area, and the Batch to the Color drop area
Jun 22, 2012
Solution
jmit
Nov 2, 2016
Thanks a bunch! I knew JMP could make it..
/JM
