BookmarkSubscribeRSS Feed
anders_bankefor
Dec 8, 2015
Try/Eval method for columns that are empty
I've tried to use examples here from disucssions regarding empty columns but with no success. Does anyone know how I can achive the following?
Depending on the imported data I will either have 1 or 6 columns with data (they will allways be imported but some will be imported without containing any data).
try (
if column contains data put it into a list
else
try next column
the 6 columns of data has a number of columns inbetween them that is not off interest. so for example:
column 1 (try/eval) column 2 (not interested in) ..... Column 6 (try/eval) etc.
I've tried the missing data pattern function and tried to modify if(NRow(Loc(IsMissing(m[0,c]))) == NRow(m) without success.
BR
Anders
Jun 22, 2012
Solution
Re: Try/Eval method for columns that are empty
Here is a simple script that will return a list with the names of all of the columns that contain data
dt = Current Data Table();
HaveDataList = {};
For( i = 1, i <= N Cols( dt ), i++,
       If( Col Number( Column( dt, i ) ) > 0,
              Insert Into( HaveDataList, Column( dt, i ) << get name )
Jun 22, 2012
Solution
HaveDataList = {};
anders_bankefor
Dec 8, 2015
This function was what I was looking for, thank you.
