robot
Community Trekker
Trouble with Report << Copy Graph
I am trying to copy a residual graph to put separately into a journal, but I am unable to copy the graph I want.  Get Picture seems to work, but I prefer an interactive graph over a static picture.  Any suggestions?  I am using JMP11.  Thanks!
// Example
dt = Open( Convert File Path( "$Sample_Data" ) || "Big Class.jmp" );
biv = dt << Bivariate(
  Y( :height ),
  X( :weight ),
  Fit Line( {Plot Residuals( 1 ), Line Color( {213, 72, 87} )} )
rbiv = biv << Report;
title = rbiv << Get Title;
rbiv[OutlineBox("Residual by X Plot")] << Select; // I can select and deselect the graph I want.
rbiv[OutlineBox("Residual by X Plot")] << Deselect;
residual = rbiv[OutlineBox("Residual by X Plot")] << Copy Graph; // I can not get this to work.
// residual = rbiv[OutlineBox("Residual by X Plot")] << Get Picture; // This works, but I prefer a graph over a picture.
out = Outline Box(title, residual);
New Window(title, out);
Re: Trouble with Report << Copy Graph
That's interesting. Is there a reason you can't just directly journal the graph? Here's an example, gluing the previous question and this one together. It doesn't do rows and columns or re-order the graphs in any way, but maybe you can plug it into your system and get what you want.
// Previous example - get all your subsets and reports
dt = Open( "$Sample_Data/Big Class.jmp" );
ages = Associative Array( :age );
currentkey = ages << First;
For( i = 1, i <= N Items( ages ), i++,
  nextkey = ages << Next( currentkey );
  ages[currentkey] = {}; // make each age hold a list
  dt << Select Where( :age == currentkey );
  // add the subset table to the list for this age:
  Insert Into(ages[currentkey], dt << Subset( Output Table Name( "Subset " || Char( currentkey ) ) ) );
  dt << Clear Select;
  // add the bivariate report to the list for this age:
  Insert Into(ages[currentkey], ages[currentkey][1] << Bivariate( Y( :height ), X( :weight ), Fit Line( {Plot Residuals( 1 ), Line Color( {213, 72, 87} )} ) ) );
  currentkey = nextkey;
Close( dt, No Save );
// Iterate through the associative array and journal the specific graph you want
  rbiv = ages[currentkey][2] << Report;
  rbiv[OutlineBox("Residual by X Plot")] << Journal;
// You could get the keys into a list and put them in some order
// and then iterate through the array using the list of keys.
// That might look something like this:
myKeys = ages << get keys;
myKeys = Sort Descending(myKeys);
For( i = 1, i <= N Items( myKeys ), i++,
  rbiv = ages[myKeys][2] << Report;
Copy Graph copies the graph and its axes onto the clipboard, where you can then use paste into another document - not interactive. Get Picture takes a picture of the graph and turns it into an image. Journals are static - they do not contain live analyses.
There is no way to get an interactive picture of a graph. The only thing I can think of is to export as interactive html, but then you have a web page, not an image. The message for that is <<Save Interactive HTML(pathname).
What is your goal?
robot
Community Trekker
Hi Melanie,
I am scripting an analysis of many residual plots, each with different test parameters (time, voltage, capacitance, etc.) and I think it would be useful to organize the residual plots in manner that is representative of these variables (IE: have graphs organized in columns by capacitance, and in rows by voltage).  To accomplish this, I am collecting residual plots and storing them in an associative array (per your earlier suggestion), and then reorganizing them in the final journal.
If possible, I would like the user to be able to zoom, adjust axes, and use the crosshair tool, as in a normal journal.  If this is not possible, a picture will work fine; I just want to make sure the user's lack of interaction is not due to my marginal knowledge of JSL.
Do you have any suggestions?
Rob
  dt << Clear Select;
robot
Community Trekker
Thanks Melanie.  I think your solution will work.  I also tried saving the residuals to the original data table and then graphing the results from there.
// Open table.
// Get residuals.
biv = Platform( dt, Bivariate( Y( :height ), X( :weight ), By( :age, :sex ), Fit Line( {Save Residuals( 1 )} ) ) );
// Get residual graphs.
  Insert Into( ages[currentkey], dt << Subset( Output Table Name( "Subset " || Char( currentkey ) ), Invisible ) );
  dt << Clear Select;
  Insert Into(
  ages[currentkey],
  Platform( ages[currentkey][1], Bivariate( Y( :Residuals height By age By sex ), X( :weight ), By( :age, :sex ) ) )
// Organize and plot data.
out = Outline Box( "Residuals height By age By sex", hb = H List Box() );
  Eval( Substitute( Expr( hb << Append( ages[currentkey][2] ) ), Expr( currentkey ), currentkey ) );
New Window( "Residuals height By age By sex", out ) << Journal;
// Close data tables.
  Close( ages[currentkey][1], No Save );
