Yngeinstn
Trouble Manipulating Tabulated Tables
I am don't quite understand why i am having issues manipulating columns from a table created from a tabulated report. I have attached the tables and scripts for your references. I am trying to create a table that matches our current report table.
Always, thanks for you help
LotListSQLString = "Wafer_1";
	tab = dt
		<< Tabulate(
		invisible,
			Add Table(
				Column Table(
					Category Table,
					Statistics(
						N,
						Name( "% of Total" )
				Row Table(
					Columns by Categories(
						:Name( "test" ),
						:Name( "[Rx] test1" ),
						:Name( "[Rx] test2" ),
						:Name( "[Rx] test3" ),
						:Name( "[Tx] test1" ),
						:Name( "[Tx] test2" ),
						:Name( "[Tx] test3" ),
						:Name( "test4" ),
						:Name( "Composite" )
	dtFinal = tab << Make Into Data Table;
	Wait( 1 );
	dtFinal << set name( " Yield Report" );
	dtFinal = New Column( "Mode",
		<< Formula(
			If( (:Columns by Categories == "test" ), "-",
				IF( :Columns by Categories == "[Rx] test1", "Rx",
					IF( :Columns by Categories == "[Rx] test2", "Rx",
						IF( :Columns by Categories == "[Rx] test3", "Rx",
							IF( :Columns by Categories == "[Tx] test1", "Tx",
								IF( :Columns by Categories == "[Tx] test2", "Tx",
									IF( :Columns by Categories == "[Tx] test3", "Tx",
										If( :Columns by Categories == "test4", "-"
	Wait( 0 );
	dtFinal = New Column( "TestName",
		<< Formula(
			If( (:Columns by Categories == "test" ), "test",
				IF( :Columns by Categories == "[Rx] test1", "test1",
					IF( :Columns by Categories == "[Rx] test2", "test2",
						IF( :Columns by Categories == "[Rx] test3", "test3",
							IF( :Columns by Categories == "[Tx] test1", "test1",
								IF( :Columns by Categories == "[Tx] test2", "test2",
									IF( :Columns by Categories == "[Tx] test3", "test3",
										If( :Columns by Categories == "test4", "test4"
// ------------------------ BEGIN FORMATING TABLE FOR FINAL REPORTING
// Says Scriptable[] but won't delete
	dtFinal << Delete Columns( {"N(Fail)", "% of Total(Fail)"} );
// Works Correctly
	dtFinal = New Column( "wafer_number",
		<< Formula(
			LotListSQLString
// Says Scriptable[] but won't go to column and obviously doesn't move
	dtFinal << Go To( "wafer_number" );
	Wait ( 0.5 );
	dtFinal << move selected Columns( To First );
	dtFinal << clear Column selection;
// Works Correctly
	dtFinal = Column( "Mode" ) << Delete Formula;
	dtFinal = Column( "TestName" ) << Delete Formula;
	dtFinal << Go To( :Mode );
	Wait ( 1 );
	dtFinal << move selected Columns( after( "wafer_number" ) );
	dtFinal << Clear Column Selection;
// Says Scriptable[] but won't go to delete
	dtFinal << Delete Columns( :Columns by Categories);
	dtFinal << go to( :TestName );
	Wait( 1 );
	dtFinal << Move Selected Column( after( "name" ) );
// Works Correctly
	lot = "XYZ";
	part = New Column( "part_number" );
	part << Set Formula( lot );
	dtFinal << go to( :part_number );
	Wait ( 1 );
// Works Correctly
	die = 334;
	numdie = New Column( "NumDie" );
	numdie << Set Formula( die );
	dtFinal<< go to( :NumDie );
	Wait ( 1 );
	dtFinalYield<< move selected Columns( after( "part_number" ) );
	dtFinalYield<< clear Column selection;
Re: Trouble Manipulating Tabulated Tables
Below is my review of your script......the issues seem to be not understanding the difference between when to use "=" and when to use "<<", and also you seem to be more careful, which sometimes relates to not totally understanding JSL.  So I strongly suggest that you read the Scripting Guide!
     Help==>Books==>Scripting Guide
Here is my annotated script
	tab = dt
		<< Tabulate(
		invisible,
			Add Table(
				Column Table(
					Category Table,
					Statistics(
						N,
				Row Table(
						:Name( "test" ),
						:Name( "test4" ),
	Wait( 1 );
	// changed from
	// dtFinal = New Column( "Mode",
	// to
	dtFinal << New Column( "Mode", character,
		// More efficient way to code the If()
		Formula(
			If(
				:Columns by Categories == "test", "-",
	Wait( 0 );
	// changed from
	// dtFinal = New Column( "TestName",
	// to
	dtFinal << New Column( "TestName", character,
		Formula(
			If(
				:Columns by Categories == "test", "test",
					"test4"
// You had not used the proper syntax in the above step, so that dtFinal
// was changed from a data table pointer to pointer to column "TestName"
// Works Correctly
	// changed from
	// dtFinal = New Column( "wafer_number",
	// to
	dtFinal << New Column( "wafer_number", character,
		<< Formula(
			LotListSQLString
	Wait ( 0.5 );
// Works Correctly
	// Changed from
	// dtFinal = Column( "Mode" ) << Delete Formula;
	// to
	dtFinal:Mode << Delete Formula;
	// Changed from
	// dtFinal = Column( "TestName" ) << Delete Formula;
	// to
	dtFinal:TestName << Delete Formula;
	// With keeping dtFinal as a pointer to the data table this now works
	// Wait ( 1 ); // not necessary wait
	//Wait( 1 );
	// changed from
	// dtFinal << Move Selected Column( after( "name" ) );
	// to
	dtFinal << Move Selected Column( after( :name("N(Pass)" ) ) );
// Works Correctly
	// This form will not work, once you save the table and reopen it
	// because the formula requires a variable named Lot
	//lot = "XYZ";
	//part = New Column( "part_number" );
	//part << Set Formula( lot );
	// here is a form that will work
	dtFinal << New Column( "part_number", character, set each value("XYZ" ) );
	//Wait ( 1 );
	// There is not a column named "name", therefore
	// changed
	// to
// Works Correctly
	// because the formula requires a variable named die
	//die = 334;
	//numdie = New Column( "NumDie" );
	//numdie << Set Formula( die );
	dtFinal << New Column( "NumDie", set each value(334) );
	//Wait ( 1 );
	// There is no pointer called dtFinalYield
	// changed from
	// dtFinalYield<< move selected Columns( after( "part_number" ) );
	// dtFinalYield<< clear Column selection;
	// to
	dtFinal << move selected Columns( after( "part_number" ) );
gianpaolo
i run your script with your data without problem....
created tabulate report and related table.... and is also possible to modify such table....
can you explain better what kind of trouble you have
ciao
Gianpaolo
Gianpaolo Polsinelli
gzmorgan0
Incorrect syntax created several name collisions:
	Wait( 1 );
As written your script expects, dtFinal to be the table reference, yet the syntax dtFinal = New Column() is assigning the new column to reference dtFinal.  The syntax should be dtFinal << New Column( )  also at the end of your script you refer to dtFinalyield, there is no such table.
Also you should look up the syntax for JMP If() functions. You do not need to nest the the ifs:
        If (cond1, result1, cond2, result2, ...condk, result k, else);
Yngeinstn
The dtFinalYield is supposed to just be dtFinal.. When i attach scripts to this forum, i have to rename everything and I missed that one.. My apologies.
I see the issues with the '=' sign instead of the '<<' I am not sure why i was doing that..
	tab = dt
		<< Tabulate(
		invisible,
			Add Table(
				Column Table(
					Category Table,
					Statistics(
						N,
				Row Table(
						:Name( "test" ),
						:Name( "test4" ),
	Wait( 1 );
	// changed from
	// to
		Formula(
			If(
	Wait( 0 );
	// changed from
	// to
		Formula(
			If(
					"test4"
// Works Correctly
	// changed from
	// to
		<< Formula(
			LotListSQLString
	Wait ( 0.5 );
// Works Correctly
	// Changed from
	// to
	// Changed from
	// to
	//Wait( 1 );
	// changed from
	// to
// Works Correctly
	//lot = "XYZ";
	//Wait ( 1 );
	// changed
	// to
// Works Correctly
	//die = 334;
	//Wait ( 1 );
	// changed from
	// to
Yngeinstn
Just getting the syntax is killing me.. Thank you for pointing that out.. Since i am still learning how to code in JSL, i most definately have both these formus, the scripting guide and the scripting index all open to search how to do things.. I missed that = to << ..
Article Labels
