BookmarkSubscribeRSS Feed
Triple-S Files and JMP: Any Advice?
mcstagger
Oct 6, 2014
Other than to get a stiff drink of course.
I am trying to open an XML and CVS file Triple-S export and am not having much luck using the Triple-S XML To JMP Data Table Importer in the file exchange. The file processes and the window for this plugin never leaves the "Importing XML file...".
Has anyone else used that particular plugin with any success?
Is there another plugin that works for this?
stan_koprowski
Community Manager
Aug 8, 2012
I am sorry to hear you are having issues with the add-in.
It appears that an error has occurred.  Can you share the files with me directly. Or you can anonymize the data using the anonymizer add-in before posting.  I'll have a look at the error and see if I can figure out how to move you forward.
Thanks,
Stan
mcstagger
Oct 6, 2014
Stan,
Thank you for responding. I will not be able to get the requested file together and I do not have a dummy data set that would represent the sets we exported. What I can share is that I believe the files were originally exported from IBM Survey Reporter.
That may not help, but that is all I have at the moment.
