ShahirahLoqman
Transforming Multiple Big Data Tables into Smaller Ones
Hi there!
So I am currently looking into analyzing the process capability of 5 polymer grades. Say one grade would have 3 physical properties that are provided by our lab that I would need to analyse.
My final target: To have 5 individual JMP files for each polymer grade consisting all 3 physical properties which are sampled with their own unique sampling time.
What I have now: I have 3 individual (and huge) physical properties file with all 5 polymer grades sampled.
My question: What's the best way for me to use my existing huge data table and extract information to create the 5 individual grade JMP files? Is subset the only way to achieve this? Is virtually joining & linking the 3 physical propeties a posibility?
Thanks in advance!
Re: Transforming Multiple Big Data Tables into Smaller Ones
It is tough to give you specific advice, not knowing the details of your data tables.  However, I will say that Subsetting is a pretty good approach.  Particularly because there is an "Subset by" option that a lot of folks miss.
This will allow for a single pass through the data with the creation of all your polymer grades.
And yes, you can create virtual links with the physical property data tables.
