BookmarkSubscribeRSS Feed
statcon
Dec 21, 2011
Tolerance Intervals for Regression
Hi JMP-Users,
im looking for tolerance intervals for simple linear regressions.
I think there is no such function in JMP9Pro, is it? I can only find confidence intervals and prediction intervals in the bivariate plattform.
Maybe some got a script or addin for tolerance intervals?
Thanks in advance!
mattf
Jun 23, 2011
Hi:
Perhaps:
dt = Open("$SAMPLE_DATA/RELIABILITY/Resistor.jmp");
dt << Distribution(
          Continuous Distribution(
               Column( : Percent Increase ),                    // note ":" and "P" in Percent Increase should be not separated by a space
               Tolerance Interval( Alpha( 0.95 ), Proportion( 0.9 ) )
Best regards,
-Matt
mattf
Jun 23, 2011
See also the JMP White Paper by Jose G. Ramirez
Statistical Intervals:Confidenec, Prediction and Enclosure
http://www.sas.com/resources/whitepaper/wo_4430.pdf
Best,
-Matt
statcon
Dec 21, 2011
Thanks for the answer but sadly thats not what i need.
Im looking for, well .. tolerance bands around a regression line.
Sorry if my question was misleading.
statcon
Dec 21, 2011
Re: Tolerance Intervals for Regression
Well i found an R package and converted the code for JMP (as i dont want to use the R-JMP Interface).
Its just for simple linear regression, but better than nothing. :-)
[Unfortunately the attachment has become corrupt here. We are contacting the author to see if it an be re-uploaded. -JMP User Community Manager]
malcolm_moore1
Jul 3, 2014
If it is a regression model with more than one predictor, then does Save Columns > Indiv Confidence Limit Formula from the Fit Model hot spot give what you are after? Both Graph Builder and Bivariate will give you equivalent prediction intervals in the case of modeling one continuous predictor on one continuous response.
