Ann_JMP_User
To generate Variability Charts based on available Y variables and save them into PNG pictures
I am trying to script some codes which will help me auto generate some variability charts based on the available column names and save them as individual PNG pictures so that I can link the pictures to my powerpoint.
But I am not sure why was the "obj" always undefined during the debug.
Would like to seek some advice on this. Thank you with much appreciation.
- Ann
dt = Open( "D:\My Drive\Program.jmp" );
// Find the Y Columns
numericColNamesList = dt << get column names( string, numeric );
For( i = N Items( numericColNamesList ), i >= 1, i--,
	If(
		Not(
			Is Missing( Num( Word( 1, numericColNamesList[i], ":" ) ) ) == 0 &
			Word( 2, numericColNamesList[i], ":" ) != ""
		numericColNamesList = Remove( numericColNamesList, i, 1 )
// With varying Y columns and fixed X columns
For( i = 2, i <= N Items( numericColNamesList ), i++,
	obj = dt << Variability Chart(
		Y( ::Column( numericColNamesList[i] ) ),
		X( :code, :lot, :Label, :wafer ),
		Analysis Type( "Choose best analysis (EMS REML Bayesian)" ),
		Connect Cell Means( 1 ),
		Std Dev Chart( 0 ),
		Automatic Recalc( 1 ),
			Dispatch(
				{"Variability Chart for numericColNamesList[i]"},
				"Variability Chart",
				FrameBox,
				{Marker Size( 6 ), Row Legend(
					Label,
					Color( 1 ),
					Color Theme( "JMP Default" ),
					Marker( 0 ),
					Marker Theme( "" ),
					Continuous Scale( 0 ),
					Reverse Scale( 0 ),
					Excluded Rows( 0 )
obj = List( obj[i] );
For( i = 1, i <= N Items( obj ), i++,
	fName = Report( obj )[Outline Box( 1 )] << Get Title;
	Report( obj )[Outline Box( 1 )] << Save Picture( "$TEMP/myPics/" || fName || ".png", "PNG" );
	Report( obj )[Outline Box( 1 )] << Save Picture( "$TEMP/myPics/" || fName || ".png", "PNG", append );
Re: To generate Variability Charts based on available Y variables and save them into PNG pictures
I modified you code.  I did not test your code, but I believe it will work.  I did not test it.
	If( Not( Is Missing( Num( Word( 1, numericColNamesList[i], ":" ) ) ) == 0 & Word( 2, numericColNamesList[i], ":" ) != "" ),
		Std Dev Chart( 0 ),
			Dispatch(
				FrameBox,
					Label,
					Color( 1 ),
					Marker( 0 ),
					Marker Theme( "" ),
					Reverse Scale( 0 ),
					Excluded Rows( 0 )
Ann_JMP_User
Thanks a lot Jim.
I tried the code, But now I have multiple windows of the Var chart appeared, but none of them were saved as PNG in the designated drive.  I guess perhaps I have missed out something near the "save picture" segment.
Ann_JMP_User
I have found the cause of it. The script is able to run now.
However, for variables with " / " in their names (example, A_B/Tox/Cap), the script will prompt error and not able to proceed on.
Report( obj ) << Save Picture( "$TEMP/myPics/" || colList[i] || ".png", PNG);
Is it due to colList[i] ?
