FN
FN
Level V
Time varying spec or control limits
For sensor data, what will be the best way to support spec or control limits that change over time (rows)?
In column properties, these attributes are constant (see below).
Re: Time varying spec or control limits
Here is an example using static control limits with phases
dt = Open( "$SAMPLE_DATA/Quality Control/Diameter.jmp" );
dt << Control Chart(
	Phase( :Phase ),
	Sample Size( :DAY ),
	KSigma( 3 ),
	Chart Col(
		:DIAMETER,
		XBar(
			Phase Level( "1", Sigma( .29 ), Avg( 4.3 ), LCL( 3.99 ), UCL( 4.72 ) ),
			Phase Level( "2", Sigma( .21 ), Avg( 4.29 ), LCL( 4 ), UCL( 4.5 ) )
		R( Phase Level( "1" ), Phase Level( "2" ) )
 The Phased limits can also be read in from a separate Limits data table
6 REPLIES 6
P_Bartell
Have you considered using a phase variable to articulate the observations and their respective limits? Quite easily done in Control Chart Builder. Here's an illustration from the JMP Online Documentation:
https://www.jmp.com/support/help/en/15.1/#page/jmp/control-chart-builder.shtml#ww1079193
FN
FN
Level V
I saw that example but these limits are automatically calculated based on statistics (see image below where I added an outlier).
But indeed, I am after a control chart were the limits are varying based on external information (e.g. production grade).
	Phase( :Phase ),
	KSigma( 3 ),
	Chart Col(
		:DIAMETER,
		XBar(
FN
FN
Level V
I have seen how to load limits from a table, but not phase limits.
Is this built-in? or we need an script as in your example?
Run my example, and then go to the red triangle and select Save Limits==>New Table.  You will then see what the table needs to look like to read in Phased limits
FN
FN
Level V
Great, I will accept your first reply. Can you add this last answer as well?
