BookmarkSubscribeRSS Feed
The output graph builder is paled
saitcopuroglu
Sep 29, 2014
I run the same script everyday several times and sometimes the graph builder output report is paled and if i click inside the graph frame it turns out to be normal... And it drives me crazy..
Anyone experienced before?
Many thanks in advance
OUTPUT w/o any touch:
OUTPUT after one click inside the graph frame:
Craige_Hales
Mar 21, 2013
Solution
You've got a row selected.  When you click, all the rows are deselected (unless you click a point).  There is a preference for the behavior:
Craige
1 REPLY
Craige_Hales
Mar 21, 2013
Solution
Craige
