BookmarkSubscribeRSS Feed
hapham
Community Trekker
Aug 11, 2016
Text Explorer: how to add the entire script to Data Table?
When I do Text Explorer "by" different categories, I didn't see the option to add the entire script to data table. Instead, I had to manually add each category. Did I miss something or is this something will be fixed for JMP 13?
Thank you !
Mar 21, 2013
Re: Text Explorer: how to add the entire script to Data Table?
It is moved in JMP 13.  From the red triangle:
hapham
Community Trekker
Aug 11, 2016
Thank you !
