BookmarkSubscribeRSS Feed
CJB007
Community Trekker
Oct 27, 2017
Text Explorer JMP13 - How do I copy out tables and wordclouds?
Hi, can someone tell me how to copy out or save as a picture the word summary tables and wordclouds that Text Explorer creates? Can't seem to find the same options as those in Graph Builder. Thanks for your help!
Mar 21, 2013
Solution
Re: Text Explorer JMP13 - How do I copy out tables and wordclouds?
Use the selection tool to select the word chart:
SelectionTool.pngThe selection tool can click-select or drag-select a region
Then use the Edit->Save Selection As menu to save the format you want.
The S and A keys also change between the Select tool and the Arrow tool.
Mar 21, 2013
Solution
CJB007
Community Trekker
Oct 27, 2017
Thanks Craige...complete brainfreeze!!
