BookmarkSubscribeSubscribe to RSS Feed
Re: Test 1000 units with two different test equipments, how to compare the equipment performance
xzhao2
Community Trekker
Jan 6, 2016
I use one test equpiment to measrue 1000 units (say, the voltage of a battery), then use another test equipment to measure these 1000 units again.      Which JMP analysis I can use to evulate the performance of the 2nd test equipment comparing to the 1st test equipment?
What I am doing now is (use excel to ) calculate the measument delta of each unit then plot the delta vs. units. Just wondering what more  professional analysis JMP can provide?
Thanks
Jason
di_michelson
Sep 10, 2014
Solution
Hi Jason,
You won't learn much about the measurement system unless you make multiple measurements on the same unit. Design and analysis of a measurement system study is a well-researched topic, similar to design of experiments on process systems.
Look at some JMP on-demand webinars: https://www.jmp.com/en_us/events/ondemand/mastering-jmp/evaluating-and-monitoring-your-process-using..., or take a training class: https://support.sas.com/edu/schedules.html?ctry=us&crs=JMSA (there is a LiveWeb class scheduled for next week!).
I hope this helps. It's great that you are asking this question and looking for more analytical answers.
--Di
di_michelson
Sep 10, 2014
Solution
Hi Jason,
--Di
xzhao2
Community Trekker
Jan 6, 2016
It really helps! Thanks!
