BookmarkSubscribe
LNitz
Tabulate interactive row drop area closes when column variable is dropped in
Jeff_Perkinson
Re: Tabulate interactive row drop area closes when column variable is dropped in
You can still drop rows into your table after setting your column, the drop area is just smaller. Here's a animated gif to show it.
If I've misunderstood, please let us know and we can help further.
-Jeff
Jeff_Perkinson
-Jeff
LNitz
Thank you, Jeff.  I had not set the variable to nominal, so the drop never worked correctly!
Setting to nominal fixed  the problem.
