Table variable and function plot
rchertzy
Jun 23, 2011
I use table variables when parameters are used in several columns, and parameters otherwise. The calculations work, but an overlay plot of a formula with one column variable does not allow a function plot, i.e., is not smooth, if the formula includes a table variable. Is this a glitch in JMP7 or is there a work around?
My bad. Had two columns with similar names and one was character. Switched to the numeric one and it works! Glitch was in the user. Sigh.
Message was edited by: RCHertzy
