jdkurtis
Community Trekker
Table rearrangement challenge
Hi-
I am trying to rearrange a table and am struggling to get the desired output. I have tried using the Summary Table, Join or Update menu functions in various permutations but have failed... any help would be extreamly appreciated- the actual table has 80,000 rows, so really can't do this manually...
I know there are no more than 10 thaw dates/thaw IDs for any given Sample ID in the real data set.
The Summary Table function quickly gets me to a table with each Sample ID listed only once (desired)- but I cannot figure out how to get the additional Thaw Date and Thaw ID columns created and populated..
thx
jake
Starting Table:
Sample IDThaw DateThaw ID
17/28/0343
27/28/0312
37/28/0332
47/28/0354
49/28/0378
411/28/0395
57/28/0358
59/28/0380
67/28/0360
Desired Output Table:
Sample IDThaw Date 1Thaw ID 1Thaw Date 2Thaw ID 2Thaw Date 3Thaw ID 3
17/28/0343
27/28/0312
37/28/0332
47/28/03549/28/037811/28/0395
57/28/03589/28/0380
67/28/0360
jerry_cooper
Staff (Retired)
Re: Table rearrangement challenge
Hi @jdkurtis ,
It might be helpful to know what analysis you're hoping to do, as it is very likely that your data are already in an analysis-ready format. Most JMP platforms play very nicely with "tall" or "stacked" data. However, the easiest way to do what you are asking is to create a new formula column containing the rank for each date within Sample ID:
Col Rank( :Thaw Date, :Sample ID )
Then just use the Tables->Split function with the following roles defined:
Split By: The new formula column
Split Columns: Thaw ID, Thaw Date
Group: Sample ID
This should give you what you're after. Hope this helps.
Once you have done your Summary on the data table, then you can use
     Tables==>Split
and Split By Thaw Date, Group on Sample ID, and having Thaw ID as the Split Columns
jdkurtis
Community Trekker
thanks so much... this got me very, very close to the desired output.. but the reply below (from jerry_cooper) got me all the way there...
I very much appreciate you taking the time to think about the problem and providing your input....
best,
jake
jerry_cooper
Staff (Retired)
Hi @jdkurtis ,
Group: Sample ID
jdkurtis
Community Trekker
Thank you so much for your answer- it worked perfectly...
I am not using this for an analysis- rather to reorganize a large database of stored samples to upload into a commercial freezer database that requires a specific format... I always turn to JMP for this type of work, but couldn't figure this one out.. I will certainly read up on the Col Rank function as this was the step I had not considered...
best,
jake
