Rich
Table Summary Script Without Hardcoding Table Names
I have a project that I will be adding tables to. I am trying to make a script that produces a summary with some basic stats.
In the following script, MyDataTable is hard coded, looking for help to replace that with something that calls up the table's name.
This my first post here, I also spent a couple of hours trying to figure it out with forum and google searches.
Thanks!!
New Table( "Summary of MyDataTable grouped by Name",
	Add Rows( 6 ),
	New Script(
		"Source",
		Data Table( "MyDataTable" ) <<
		Summary(
			Group( :Name ),
			Mean( :Resp. ),
			Std Dev( :Resp. ),
			Std Err( :Resp. ),
			N( :Resp. ),
			Freq( "None" ),
			Weight( "None" ),
			output table name( "Summary of MyDataTable grouped by Name" )
	New Column( "Name",
		Character( 20 ),
		"Nominal",
		Lock( 1 ),
		Set Display Width( 83 )
	New Column( "N Rows",
		Numeric,
		"Continuous",
		Format( "Fixed Dec", 12, 0 ),
		Lock( 1 ),
		Set Display Width( 42 )
	New Column( "Mean(Resp.)",
		Numeric,
		"Continuous",
		Set Selected,
		Lock( 1 ),
		Set Display Width( 70 )
	New Column( "Std Dev(Resp.)",
		Numeric,
		"Continuous",
		Set Selected,
		Lock( 1 ),
	New Column( "Std Err(Resp.)",
		Numeric,
		"Continuous",
		Set Selected,
		Lock( 1 ),
		Set Display Width( 77 )
	New Column( "N(Resp.)",
		Numeric,
		"Continuous",
		Format( "Best", 12 ),
		Lock( 1 ),
		Set Display Width( 48 )
hogi
Level XIII
Re: Table Summary Script Without Hardcoding Table Names
In the above case, it is just the part
Summary(
	Group( :Name ),
	Mean( :Resp. ),
	Std Dev( :Resp. ),
	Std Err( :Resp. ),
	N( :Resp. )
Just import the column from Excel and execute the code.
8 REPLIES 8
Where is the "MyDataTable" coming from? How do you define which table should be used when? Are you saving this script to some other data table than MyDataTable?
Rich
I am using the JMP add-in in Excel to create the data table. MyDataTable is the name of the table from Excel. So my thought was when I add more data tables to my project, I can run the script to generate my summary table(s). Maybe there is an easier/cleaner way? I did try selecting multiple tables then generate the summary (Table>Summary dropdown), but it only generated the summary for one table. SO maybe I am missing a step there?
If all the tables have same column names, you could have a simple script in the project which would create a summary of the current data table which you run as needed. Other option could be to loop over the tables in your project and creating summaries which are still missing but this does require quite a bit of extra scripting. You might also be able to load the data directly to JMP without using the add-in and create the summary immediately after the data is loaded.
hogi
Level XIII
Summary(
	Group( :Name ),
	Mean( :Resp. ),
	Std Dev( :Resp. ),
	Std Err( :Resp. ),
	N( :Resp. )
Rich
Thanks jthi and hogi!
I will try to figure out where to save the script in the project instead of associated with a table.
hogi
Level XIII
You might have a look at:
Workflow Builder or the "baby steps" into Scripting
Depending on the total length of your workflow, it might be suitable to store the workflow for the data import and the processing  separate from a project or from the actual data.
As
... if the column names vary, it gets a bit more complicated ...
Rich
I will give this a look tomorrow!!
Rich
Thank you both. Very helpful!!
