Table Box with multiline cells
Just noticed slight problem (one more to the long list of problems) with Table Box. I'm trying to add fairly long string to Table Box and because Table Box doesn't really support multiple lines I tried using Col Box with Table Box(<< Set Wrap())... issue with this is that it seems to break everything else
tb = Table Box(
	nceb = Number Col Edit Box("Order", []),
	scb1 = String Col Box("103width", {}),
	cb = Col Box("longstring", {}),
	scb2 = String Col Box("104width", {}),
nceb << Set Width(40);
scb1 << Set Width(103);
scb2 << Set Width(104);
New window("",
	tb
textb = Text Box("AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAADDD", << Set Wrap(150));
long_str = "speciallylongname";
Eval(EvalExpr(
	tb << Add Row({1, Expr(long_str), Expr(textb), Expr(long_str)});
Seems like 103width is being wrapped and only second line is being show.
Does anyone have any good ideas how I could handle this? These three come to my mind quickly:
  1. Do I have to only use Col Boxes with Text Boxes and just accept that I can't let users select rows in Table Box as easily as I would like to?
  2. Do I have to write my custom class for new display box element (as in give up with Table Boxes)
  3. Create hidden columns with full text and then calculate max width I can show in String Col Boxes and only show those.
Re: Table Box with multiline cells
I ran your script and got different results.
and even more confusing results by adding a second line to the table
Using Col Box() with embedded Text Boxes seems to help
@txnelson Differences in the first case could be caused by different font settings (or maybe even zoom levels?) as the widths are set by using pixels to my understanding.
Second case is a bit worrying, as it looks like that rows are getting mixed up somehow. Most likely getting text from wrong row:
 (changed long_str = "11231231312312312312"; for second row).
Using Col Box with textboxes might be the "only" solution for now. Too bad you can't click and highlight rows with just setting tb << Set Selectable Rows(1); when using col boxes.
Also because Table Box seems to have fixed height for each row, it might be beneficial to wrap Text Box() with Scroll Box() (this will make the column a bit wider if scroll box appears)
tb = Table Box(
New window("",
	tb
textb = Scroll Box(Size(175, 35),
	Text Box("AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA", << Set Wrap(150))
	, <<Set Auto Stretching(0, 0)
	, << Set Show Empty(0, 0)
);Eval(EvalExpr(
	Text Box("AAAA", << Set Wrap(150))
);Eval(EvalExpr(
	Text Box("AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA", << Set Wrap(150))
Eval(EvalExpr(
David_Burnham
I tend to populate table boxes column-wise so I tried this:
nceb << set({1});
scb1 << set({long_str});
scb2 << set({long_str});
wait(2);
cb << set(lstBoxes);
But the same problem occurred.  The only way I could get it to work was to also have scb1 and a Col Box containing Text Boxes.  I've typically resorted to making the first column of a table box contain Radio Buttons to allow selections:
-Dave
