The World Statistics Day celebration continues here in the Community. We all need reliable data for sound decision making. Do you have a data source that you trust most? Head over to Discussions to tell us about it.
viskovicz00012
Tab Box to Ppt
Is there a way to append contents of the tabs in the Tab Box to a ppt slide?
Re: Tab Box to Ppt
Are you having issues with saving Tabs to pptx?  When you tried it, what error messages did you get?
This is something I do on a regular basis.
Below is a simple piece of code that I put together that works without issue with JMP 15 under Windows 10
dt=open("$SAMPLE_DATA/big class.jmp");
nw=New Window( "Example",
	Tab Box(
		tp = Tab Page Box(
			Title( "One" ),
			Distribution( Continuous Distribution( Column( :height ) ) )
		Tab Page Box( Title( "two" ), Bivariate( Y( :height ), X( :weight ) ) )
nw<<save presentation("$TEMP/tabs.pptx");
open("$TEMP/tabs.pptx");
