hans_deroos
Switching between journals
//This question was asked earier but don't see an answer
dist = dt << Distribution( Y( :height ), CDF Plot( 1 ));
J1=new window("Journal1",<<Journal);
Rep1=Report( dist )["CDF Plot"];
Rep1<<Journal();
J2=new window("Journal2",<<Journal);
Rep2=Report( dist);
Rep2<<Journal();
J1<<append(text box(" To Journal 1 "));
Rep1<<Journal();   // I want this report added to journal1
Re: Switching between journals
Rep1 << Journal() sends its object to the current journal, so can be hard to control.
You can append to a specific journal, though. Instead of your last line:
try this instead:
J1 << Append(Rep1)
If you append to a specific journal, then you can control which one you're adding reports to.
HTH,
Melanie
try this instead:
J1 << Append(Rep1)
HTH,
Melanie
hans_deroos
Hi Melanie
Makes absolute sense.
Thanks for the fast response
