jswislar
Survival analysis with clustered data?
Is it possible to account for clustering in survival analysis (Marginal hazards) in JMP Pro?
I'm currently modeling procedure failure rates per tooth, but teeth are clustered within individuals, so I think the analyses should account for this. Can this be done with JMP? I don't see any options in the proportional hazards selections, but there is a "grouping" option in the simple survival analysis.
Thanks
Re: Survival analysis with clustered data?
I think that you are referring to frailty models in which there are group parameters for the life distribution of survival. Such models are not available in JMP at this time.
You can learn more about them starting here.
Article Labels
