Seddod
Survival Analysis on Continuous Data
Hey,
I'm trying to run a survival analysis for a continuous data type, age, but the analysis is giving me the data for each individual age (i.e.  survival for 20, 21, 22, 23 year olds) as opposed to the overall data set.
I checked the "Combined" tab in the analysis but it was also not giving a single overall p-value, and other stats. Maybe I am overlooking something?
Thanks
Re: Survival Analysis on Continuous Data
Exactly how did you assign data columns to the analysis roles in the Survival launch dialog box? From what you described, you only need to put the data column with the age values in the Y, Time to Event role.
