BookmarkSubscribeRSS Feed
Summary/renaming a column
is there a way to specify a column name for statistics calculated using summary?
so far I have
summary(
group(:byvar1),
mean(:datavar1),
output table name("Means"));
I end up with a variable called mean(Datavar1) and I would like to assign it a different name.
mattf
Jun 23, 2011
Re: Summary/renaming a column
Hi:
On the summary platform dialog - look to the lower left side where a pull-down offers several options for the newly created column name, including:
stat(column) (the default)
column
stat of column
column stat
e.g.
