robot
Summary of Unknown Number of Columns
I would like to create a summary of all columns in a generic data table, where the number of columns are unknown.
Below is an example for a known data table.  Any suggestions for an unknown number of columns?
Thanks,
Rob
dt = Open( "$SAMPLE_DATA/Big Class.JMP" );
dtsum1 = dt << Summary( N( :name ), N( :age ), N( :sex ), N( :height ), N( :weight ) );
ms
Super User ms
Re: Summary of Unknown Number of Columns
Summary accepts a list of columns as an argument. So this oneliner works too!
dt<<Summary(N(dt<<get column names));
pmroz
There's probably a slicker way, but in situations like this I create dynamic code and then execute it:
dt_cols = dt << get column names(string);
for (i = 1, i <= nitems(dt_cols), i++,
    if (i == 1,
        n_expr = "dtsum1 = dt << Summary( N(:name(\!"" ||
                  dt_cols[i] || "\!"))";
        n_expr = n_expr || ", N(:name(\!"" || dt_cols[i] || "\!"))";
n_expr = n_expr || ")";
eval(parse(n_expr));
adamrauk
I suggest building an expression and then inserting references to each column:
summaryexpr=Expr(Summary());
for(i=1,i<=ncol(dt),i++,
  insertinto(summaryexpr,insert(expr(N()),column(i)))
eval(substitute(expr(dt<<command),expr(command),summaryexpr));
Unless you are switching between data tables, you could simplify the last line by simply executing 'summaryexpr' rather than adding it as a command to 'dt'.
robot
Both solutions work great.  Thanks!
ms
Super User ms
robot
Very elegant.  Thanks!
