Hegedus
Summary Table
I would like to script the creation of a summary table with the minimum value of each column, with the caveat I do not know the number or name of the columns ahead of time.  It can vary with different input files.  If I do it manually I get a script tied to the specific column names in my example table. What do I need to change in the Min(.... section to pass all the column names?
Data Table( "FSL Card CRes Pd Chuck Return 2" ) <<
Summary(
  Min( :Name( "1" ) ),
  Min( :Name( "2" ) ),
  Min( :Name( "3" ) ),
  Min( :Name( "4" ) ),
  Min( :Name( "5" ) ),
  Min( :Name( "6" ) ),
  Min( :Name( "7" ) ),
  Min( :Name( "8" ) ),
  Min( :Name( "9" ) ),
  Min( :Name( "10" ) ),
  Min( :Name( "11" ) ),
  Min( :Name( "12" ) ),
  Freq( "None" ),
  Weight( "None" ),
  statistics column name format( "column" )
This does not work
CrefDT=current data table();
CRefMinDT = Data Table( CRefDT ) << Summary(
  min( (columns( CRefDT << get column names ))),
  Freq( "None" ),
  Weight( "None" ),
Hegedus
Re: Summary Table
Figured it out.
  min( CRefDT << get column names )),
  Freq( "None" ),
  Weight( "None" ),
I seem to have use different syntax for the column list depending for update vs. join vs. split vs. stack.  Very confusing.
