Ding
Substituting a direct data type into WHERE clause
Hi I am new to JMP and my knowledge about scripting is very basic.
There is an existing script done by an ex-colleague which I would like to edit for a similar function.
What the script does is pull data from a database filtered by a specific data and time entered by the user.
I want to change the data being pulled in the WHERE clause with another similar data type.
For my case; I tried substituting "PalletizedDate" with "CTI_Date" which both have the same date formats.
However, the script would not run after just making this one change.
I studied the script intensely and looked through tutorials on JMP and SQL but I can figure out the logic of the error.
from [dbo].[v_ModulePowerCellCTI]
WHERE (Tracking_Line LIKE 'LineSelect') AND (PalletizedDate BETWEEN 'DateBegin' AND 'DateStop') AND (Tracking_Train LIKE 'TrainSelect')
clear globals();
clear log();
DateStrt = MDYHMS( Today() - 1 * 24 * 60 * 60 );
DateE = MDYHMS( Today() );
db = Dialog(
	"Production Module Data (Module, Cell and Wafer data)",
	"--------------------------------------- 24 Aug 2017 v1.63",
	Vlist( Lineup( 2, "Start Date", startdate = edittext( DateStrt ), "End Date", enddate = edittext( DateE ) ) ),
	Hlist(
		Vlist( "Select Line", Lines = radiobuttons( "Line1", "Line2", "Line3", "Line4", "Line5", "Line6", "ALL" ) ),
		Vlist( "Select Train", Trains = radiobuttons( "ALL", "A", "B" ) ),
		Vlist( " Which data?", WCD = radiobuttons( "M", "M+C", "M+C+W" ),"M-Modules
C-Cell
W-Wafer" ),
		Vlist("CTM results?", GT = radiobuttons("No","Yes")),
		Hlist( "", Button( "OK" ), Button( "CANCEL" ) )
Lines = db["Lines"];
Linename = Match( Lines, 1, "1", 2, "2", 3, "3", 4, "4", 5, "5", 6, "6", 7, "%" );
Trains = db["Trains"];
Trainname = Match( Trains, 1, "%", 2, "A", 3, "B" );
WCD = db["WCD"];
GT = db["GT"];
startdate = db["startdate"];
enddate = db["enddate"];
bt = db["button"];
If( db["Button"] == -1,
	Throw( "Canceling script" ) );
// Cell data indciated as CTI,
If( WCD == 1,
	SQLJ =
Select distinct
PalletizedDate AS DateTime,
Line,
Serial,
Module,
Power,
CellOrigin,
CellPaste,
CellEff,
MaxWatt AS Pmp,
MaxVolt AS Voc,
MaxAmp AS Isc,
Vmpp,
Impp,
Fill_Factor,
AmbTemp,
RefTemp,
CEL,
SO,
EVA,
BackSheet,
JunctionBox,
Frame,
Ribbon,
Lamp1,
Lamp2,
Lamp3,
Lamp4,
Lamp5,
Lamp6,
Laminator_No AS LamNo,
LamPosition
group by
PalletizedDate,
Line,
Serial,
Module,
Power,
CellOrigin,
CellPaste,
CellEff,
MaxWatt,
MaxVolt,
MaxAmp,
Vmpp,
Impp,
Fill_Factor,
AmbTemp,
RefTemp,
CEL,
SO,
EVA,
BackSheet,
JunctionBox,
Frame,
Ribbon,
Lamp1,
Lamp2,
Lamp3,
Lamp4,
Lamp5,
Lamp6,
Laminator_No,
LamPosition
order by PalletizedDate";
	SQL1 = Substitute( SQLJ, Expr( LineSelect ), Linename, Expr( DateBegin ), startdate, Expr( DateStop ), enddate, expr(TrainSelect), Trainname ); //express terms in SQL so data can be filtered
	Open Database(
		"Description=Cell SQL;DRIVER=SQL Server;SERVER=tuaap202smvm\recdw;UID=;Trusted_Connection=Yes;APP=Microsoft® Windows® Operating System;WSID=xxxxxxx",
		SQL1
// Formating starts here //
	dt = Current Data Table();
	dt << setname( "Production Data" );
	dt << select where( Right( :Module, 2 ) == "Q2" | Right( :Module, 2 ) == "Q3" | (:Module == "Scrap Module") | (:Module == "Scrap Laminate") ) <<
	delete rows;
	Column( "DateTime" ) << data type( numeric ) << Format( "m/d/y h:m:s" ) << modeling type( continuous );
	New Column( "Day", Numeric, Nominal, Formula( Shortdate( DateTime ) ) ); //create new column for day number
	New Column( "Hour", Numeric, Nominal, Formula( Hour( DateTime ) ) ); //create new column for Hour
	Column( "CellEff" ) << data type( numeric ) << modeling type( nominal );
	Column( "Lamp1" ) << hide( 1 );
	Column( "Lamp2" ) << hide( 1 );
	Column( "Lamp3" ) << hide( 1 );
	Column( "Lamp4" ) << hide( 1 );
	Column( "Lamp5" ) << hide( 1 );
	Column( "Lamp6" ) << hide( 1 ); //Hide Lamp data as L5 and 6 not rdy for lamp data extraction
If( WCD == 2,
	SQLJ =
Select distinct
Line,
Serial,
Module,
Power,
CellOrigin,
CellPaste,
CellEff,
MaxWatt AS Pmp,
MaxVolt AS Voc,
MaxAmp AS Isc,
Vmpp,
Impp,
Fill_Factor,
AmbTemp,
RefTemp,
CEL,
SO,
CellBoxID,
NumberOfCells,
Rs,
Cell_Line,
CTI_Date AS Cell_Date,
CTI_Isc AS Cell_Isc,
CTI_Voc AS Cell_Voc,
CTI_FF AS Cell_FF,
CTI_NCell AS Cell_NCell,
EVA,
BackSheet,
JunctionBox,
Frame,
Ribbon,
Lamp1,
Lamp2,
Lamp3,
Lamp4,
Lamp5,
Lamp6,
LamPosition
	Open Database(
		SQL1
	dt3 = Current Data Table();
	dt2 = dt3 << Summary(
    Group( :Serial )
	dt = dt3 << Join(
    With( dt2 ),
    Update,
    By Matching Columns(:Serial = :Serial),
    Drop multiples( 1, 0 ),
    Name( "Include non-matches" )(0, 0),
    Preserve main table order( 1 ),
	Close(dt2, no save);
	Close(dt3, no save);
	dt << select where( Right( :Module, 2 ) == "Q2" | Right( :Module, 2 ) == "Q3" | (:Module == "Scrap Module") | (:Module == "Scrap Laminate") ) << delete rows;
	Column( "NumberOfCells" ) << data type( numeric ) << modeling type( Continuous );
	New Column( "Day", Numeric, Nominal, Formula( shortdate( DateTime ) ) ); //create new column for day number
	New Column( "CellDate", Numeric, Nominal, Formula( shortdate (Cell_Date) ) ); //create new column for Celldate
	New Column( "CTM Voc", Numeric, Continuous, Formula( ( :Voc/:NumberOfCells ) - :Cell_Voc ) , EvalFormula ); //create new column for CTM Voc
	New Column( "CTM Isc", Numeric, Continuous, Formula( :Isc - :Cell_Isc ) , EvalFormula ); //create new column for CTM Isc
	New Column( "CTM FF", Numeric, Continuous, Formula( :Fill_Factor - :Cell_FF ) , EvalFormula ); //create new column for CTM FF
	New Column( "Ncell delta", Continuous, Nominal, Formula( (:Cell_NCell*100) - (:CellEff/100) ) , EvalFormula ); //create new column for Ncell delta
If(GT==2,
	dt << Tabulate(
	Show Control Panel( 0 ),
	Set Format( N( 9, "Best" ) ),
	Add Table(
		Column Table(
			Analysis Columns(
				:Pmp,
				:Voc,
				:Isc,
				:Fill_Factor,
				:Cell_Voc,
				:Cell_Isc,
				:Cell_FF,
				:Cell_NCell,
				:CTM Voc,
				:CTM Isc,
				:CTM FF,
				:Ncell delta,
				:Rs
			Statistics( Mean )
		Column Table( Statistics ( N ) ),
		Row Table( Grouping Columns( :CellPaste,:Cell_Line,:CellEff,:CellDate) )
If(GT==2,
Variability Chart(SendToByGroup({:Line == "L6A"}), Y(:Pmp, :Voc, :Isc, :Vmpp, :Impp, :Fill_Factor), SendToByGroup({:Line == "L6A"}, Y(:Pmp)), SendToByGroup({:Line == "L6A", Platform Index(2)}, Y(:Voc)), SendToByGroup({:Line == "L6A", Platform Index(3)}, Y(:Isc)), SendToByGroup({:Line == "L6A", Platform Index(4)}, Y(:Vmpp)), SendToByGroup({:Line == "L6A", Platform Index(5)}, Y(:Impp)), SendToByGroup({:Line == "L6A", Platform Index(6)}, Y(:Fill_Factor)), SendToByGroup({:Line == "L6B"}, Y(:Pmp)), SendToByGroup({:Line == "L6B", Platform Index(2)}, Y(:Voc)), SendToByGroup({:Line == "L6B", Platform Index(3)}, Y(:Isc)), SendToByGroup({:Line == "L6B", Platform Index(4)}, Y(:Vmpp)), SendToByGroup({:Line == "L6B", Platform Index(5)}, Y(:Impp)), SendToByGroup({:Line == "L6B", Platform Index(6)}, Y(:Fill_Factor)), X(:CellEff, :Day, :CellDay), Max Iter(100), Conv Limit(0.00000001), Number Integration Abscissas(128), Number Function Evals(65536), Analysis Type("Choose best analysis (EMS REML Bayesian)"), Show Range Bars(0), Connect Cell Means(1), Std Dev Chart(0), Points Jittered(1), Show Box Plots(1), Mean Diamonds(1), By(:Line), SendToByGroup({:Line == "L6A"}, SendToReport(Dispatch({"Variability Gauge Line=L6A", "Variability Chart for Pmp"}, "Variability Chart", FrameBox, {DispatchSeg(BoxPlotSeg(1), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(2), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(3), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(4), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(5), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(6), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(7), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(8), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(9), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(10), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(11), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(12), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(13), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(14), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(15), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(16), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(17), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(18), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(19), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(20), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(21), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(22), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(23), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(24), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(25), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(26), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(27), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(28), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(29), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(30), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(31), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(32), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(33), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(34), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(35), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(36), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(37), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(38), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(39), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(40), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(41), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(42), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(43), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(44), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(45), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(46), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(47), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(48), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(49), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(50), {Box Type("Outlier"), Line Color("Red")})}))), SendToByGroup({:Line == "L6A", Platform Index(2)}, SendToReport(Dispatch({"Variability Gauge Line=L6A", "Variability Chart for Voc"}, "Variability Chart", FrameBox, {DispatchSeg(BoxPlotSeg(1), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(2), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(3), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(4), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(5), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(6), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(7), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(8), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(9), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(10), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(11), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(12), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(13), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(14), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(15), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(16), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(17), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(18), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(19), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(20), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(21), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(22), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(23), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(24), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(25), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(26), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(27), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(28), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(29), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(30), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(31), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(32), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(33), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(34), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(35), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(36), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(37), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(38), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(39), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(40), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(41), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(42), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(43), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(44), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(45), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(46), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(47), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(48), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(49), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(50), {Box Type("Outlier"), Line Color("Red")})}))), SendToByGroup({:Line == "L6A", Platform Index(3)}, SendToReport(Dispatch({"Variability Gauge Line=L6A", "Variability Chart for Isc"}, "Variability Chart", FrameBox, {DispatchSeg(BoxPlotSeg(1), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(2), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(3), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(4), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(5), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(6), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(7), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(8), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(9), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(10), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(11), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(12), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(13), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(14), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(15), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(16), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(17), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(18), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(19), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(20), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(21), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(22), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(23), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(24), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(25), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(26), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(27), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(28), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(29), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(30), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(31), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(32), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(33), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(34), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(35), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(36), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(37), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(38), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(39), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(40), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(41), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(42), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(43), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(44), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(45), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(46), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(47), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(48), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(49), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(50), {Box Type("Outlier"), Line Color("Red")})}))), SendToByGroup({:Line == "L6A", Platform Index(4)}, SendToReport(Dispatch({"Variability Gauge Line=L6A", "Variability Chart for Vmpp"}, "Variability Chart", FrameBox, {DispatchSeg(BoxPlotSeg(1), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(2), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(3), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(4), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(5), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(6), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(7), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(8), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(9), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(10), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(11), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(12), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(13), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(14), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(15), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(16), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(17), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(18), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(19), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(20), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(21), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(22), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(23), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(24), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(25), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(26), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(27), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(28), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(29), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(30), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(31), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(32), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(33), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(34), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(35), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(36), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(37), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(38), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(39), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(40), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(41), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(42), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(43), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(44), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(45), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(46), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(47), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(48), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(49), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(50), {Box Type("Outlier"), Line Color("Red")})}))), SendToByGroup({:Line == "L6A", Platform Index(5)}, SendToReport(Dispatch({"Variability Gauge Line=L6A", "Variability Chart for Impp"}, "Variability Chart", FrameBox, {DispatchSeg(BoxPlotSeg(1), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(2), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(3), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(4), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(5), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(6), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(7), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(8), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(9), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(10), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(11), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(12), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(13), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(14), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(15), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(16), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(17), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(18), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(19), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(20), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(21), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(22), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(23), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(24), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(25), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(26), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(27), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(28), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(29), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(30), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(31), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(32), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(33), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(34), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(35), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(36), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(37), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(38), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(39), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(40), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(41), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(42), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(43), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(44), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(45), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(46), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(47), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(48), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(49), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(50), {Box Type("Outlier"), Line Color("Red")})}))), SendToByGroup({:Line == "L6A", Platform Index(6)}, SendToReport(Dispatch({"Variability Gauge Line=L6A", "Variability Chart for Fill_Factor"}, "Variability Chart", FrameBox, {DispatchSeg(BoxPlotSeg(1), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(2), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(3), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(4), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(5), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(6), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(7), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(8), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(9), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(10), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(11), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(12), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(13), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(14), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(15), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(16), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(17), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(18), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(19), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(20), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(21), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(22), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(23), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(24), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(25), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(26), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(27), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(28), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(29), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(30), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(31), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(32), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(33), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(34), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(35), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(36), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(37), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(38), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(39), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(40), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(41), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(42), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(43), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(44), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(45), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(46), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(47), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(48), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(49), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(50), {Box Type("Outlier"), Line Color("Red")})}))), SendToByGroup({:Line == "L6B"}, SendToReport(Dispatch({"Variability Gauge Line=L6B", "Variability Chart for Pmp"}, "Variability Chart", FrameBox, {DispatchSeg(BoxPlotSeg(1), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(2), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(3), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(4), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(5), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(6), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(7), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(8), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(9), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(10), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(11), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(12), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(13), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(14), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(15), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(16), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(17), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(18), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(19), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(20), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(21), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(22), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(23), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(24), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(25), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(26), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(27), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(28), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(29), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(30), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(31), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(32), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(33), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(34), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(35), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(36), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(37), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(38), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(39), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(40), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(41), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(42), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(43), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(44), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(45), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(46), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(47), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(48), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(49), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(50), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(51), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(52), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(53), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(54), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(55), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(56), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(57), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(58), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(59), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(60), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(61), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(62), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(63), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(64), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(65), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(66), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(67), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(68), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(69), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(70), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(71), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(72), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(73), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(74), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(75), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(76), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(77), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(78), {Box Type("Outlier"), Line Color("Red")})}))), SendToByGroup({:Line == "L6B", Platform Index(2)}, SendToReport(Dispatch({"Variability Gauge Line=L6B", "Variability Chart for Voc"}, "Variability Chart", FrameBox, {DispatchSeg(BoxPlotSeg(1), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(2), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(3), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(4), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(5), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(6), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(7), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(8), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(9), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(10), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(11), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(12), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(13), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(14), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(15), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(16), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(17), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(18), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(19), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(20), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(21), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(22), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(23), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(24), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(25), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(26), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(27), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(28), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(29), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(30), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(31), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(32), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(33), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(34), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(35), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(36), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(37), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(38), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(39), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(40), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(41), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(42), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(43), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(44), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(45), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(46), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(47), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(48), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(49), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(50), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(51), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(52), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(53), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(54), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(55), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(56), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(57), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(58), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(59), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(60), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(61), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(62), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(63), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(64), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(65), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(66), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(67), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(68), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(69), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(70), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(71), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(72), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(73), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(74), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(75), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(76), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(77), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(78), {Box Type("Outlier"), Line Color("Red")})}))), SendToByGroup({:Line == "L6B", Platform Index(3)}, SendToReport(Dispatch({"Variability Gauge Line=L6B", "Variability Chart for Isc"}, "Variability Chart", FrameBox, {DispatchSeg(BoxPlotSeg(1), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(2), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(3), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(4), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(5), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(6), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(7), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(8), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(9), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(10), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(11), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(12), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(13), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(14), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(15), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(16), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(17), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(18), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(19), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(20), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(21), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(22), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(23), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(24), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(25), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(26), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(27), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(28), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(29), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(30), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(31), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(32), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(33), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(34), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(35), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(36), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(37), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(38), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(39), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(40), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(41), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(42), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(43), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(44), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(45), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(46), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(47), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(48), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(49), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(50), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(51), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(52), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(53), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(54), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(55), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(56), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(57), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(58), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(59), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(60), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(61), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(62), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(63), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(64), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(65), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(66), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(67), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(68), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(69), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(70), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(71), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(72), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(73), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(74), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(75), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(76), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(77), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(78), {Box Type("Outlier"), Line Color("Red")})}))), SendToByGroup({:Line == "L6B", Platform Index(4)}, SendToReport(Dispatch({"Variability Gauge Line=L6B", "Variability Chart for Vmpp"}, "Variability Chart", FrameBox, {DispatchSeg(BoxPlotSeg(1), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(2), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(3), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(4), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(5), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(6), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(7), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(8), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(9), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(10), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(11), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(12), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(13), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(14), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(15), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(16), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(17), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(18), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(19), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(20), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(21), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(22), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(23), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(24), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(25), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(26), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(27), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(28), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(29), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(30), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(31), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(32), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(33), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(34), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(35), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(36), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(37), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(38), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(39), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(40), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(41), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(42), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(43), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(44), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(45), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(46), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(47), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(48), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(49), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(50), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(51), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(52), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(53), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(54), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(55), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(56), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(57), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(58), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(59), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(60), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(61), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(62), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(63), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(64), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(65), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(66), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(67), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(68), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(69), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(70), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(71), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(72), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(73), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(74), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(75), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(76), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(77), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(78), {Box Type("Outlier"), Line Color("Red")})}))), SendToByGroup({:Line == "L6B", Platform Index(5)}, SendToReport(Dispatch({"Variability Gauge Line=L6B", "Variability Chart for Impp"}, "Variability Chart", FrameBox, {DispatchSeg(BoxPlotSeg(1), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(2), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(3), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(4), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(5), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(6), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(7), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(8), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(9), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(10), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(11), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(12), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(13), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(14), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(15), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(16), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(17), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(18), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(19), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(20), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(21), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(22), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(23), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(24), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(25), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(26), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(27), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(28), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(29), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(30), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(31), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(32), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(33), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(34), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(35), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(36), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(37), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(38), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(39), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(40), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(41), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(42), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(43), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(44), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(45), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(46), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(47), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(48), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(49), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(50), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(51), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(52), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(53), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(54), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(55), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(56), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(57), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(58), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(59), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(60), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(61), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(62), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(63), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(64), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(65), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(66), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(67), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(68), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(69), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(70), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(71), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(72), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(73), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(74), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(75), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(76), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(77), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(78), {Box Type("Outlier"), Line Color("Red")})}))), SendToByGroup({:Line == "L6B", Platform Index(6)}, SendToReport(Dispatch({"Variability Gauge Line=L6B", "Variability Chart for Fill_Factor"}, "Variability Chart", FrameBox, {DispatchSeg(BoxPlotSeg(1), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(2), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(3), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(4), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(5), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(6), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(7), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(8), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(9), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(10), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(11), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(12), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(13), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(14), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(15), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(16), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(17), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(18), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(19), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(20), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(21), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(22), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(23), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(24), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(25), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(26), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(27), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(28), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(29), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(30), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(31), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(32), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(33), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(34), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(35), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(36), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(37), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(38), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(39), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(40), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(41), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(42), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(43), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(44), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(45), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(46), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(47), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(48), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(49), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(50), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(51), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(52), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(53), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(54), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(55), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(56), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(57), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(58), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(59), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(60), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(61), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(62), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(63), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(64), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(65), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(66), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(67), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(68), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(69), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(70), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(71), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(72), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(73), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(74), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(75), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(76), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(77), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(78), {Box Type("Outlier"), Line Color("Red")})}))))
If( WCD == 3,
	SQLJ =
Select distinct
PalletizedDate AS DateTime,
Line,
Serial,
Module,
Power,
CellOrigin,
CellPaste,
CellEff,
MaxWatt AS Pmp,
MaxVolt AS Voc,
MaxAmp AS Isc,
Vmpp,
Impp,
Fill_Factor,
AmbTemp,
RefTemp,
CEL,
SO,
NumberOfCells,
Rs,
BatchID,
WaferID,
BlockSection AS WaferBlockSection,
Cell_Line,
CTI_FF AS Cell_FF,
EVA,
BackSheet,
JunctionBox,
Frame,
Ribbon,
Lamp1,
Lamp2,
Lamp3,
Lamp4,
Lamp5,
Lamp6,
Laminator_No AS LamNo,
LamPosition
from [dbo].[v_ModulePowerCellCTI]
WHERE (Tracking_Line LIKE 'LineSelect') AND (PalletizedDate BETWEEN 'DateBegin' AND 'DateStop') AND (Tracking_Train LIKE 'TrainSelect')
order by PalletizedDate";
	SQL1 = Substitute( SQLJ, Expr( LineSelect ), Linename, Expr( DateBegin ), startdate, Expr( DateStop ), enddate, expr(TrainSelect), Trainname ); //express terms in SQL so data can be filtered
	Open Database(
		"Description=Cell SQL;DRIVER=SQL Server;SERVER=tuaap202smvm\recdw;UID=;Trusted_Connection=Yes;APP=Microsoft® Windows® Operating System;WSID=xxxxxxx",
		SQL1
// Formating starts here //
	dt3 = Current Data Table();
	dt2 = dt3 << Summary(
    Group( :Serial )
	dt = dt3 << Join(
    With( dt2 ),
    Update,
    By Matching Columns(:Serial = :Serial),
    Drop multiples( 1, 0 ),
    Name( "Include non-matches" )(0, 0),
    Preserve main table order( 1 ),
	Close(dt2, no save);
	Close(dt3, no save);
	dt << setname( "Production Data" );
	dt << select where( Right( :Module, 2 ) == "Q2" | Right( :Module, 2 ) == "Q3" | (:Module == "Scrap Module") | (:Module == "Scrap Laminate") ) << delete rows;
	Column( "DateTime" ) << data type( numeric ) << Format( "m/d/y h:m:s" ) << modeling type( continuous );
	Column( "NumberOfCells" ) << data type( numeric ) << modeling type( Continuous );
	New Column( "Day", Numeric, Nominal, Formula( shortdate( DateTime ) ) ); //create new column for day number
	New Column( "Hour", Numeric, Nominal, Formula( Hour( DateTime ) ) ); //create new column for Hour
	New Column( "CellDate", Numeric, Nominal, Formula( shortdate (Cell_Date) ) ); //create new column for Celldate
	New Column( "CTM Voc", Numeric, Continuous, Formula( ( :Voc/:NumberOfCells ) - :Cell_Voc ) , EvalFormula ); //create new column for CTM Voc
	New Column( "CTM Isc", Numeric, Continuous, Formula( :Isc - :Cell_Isc ) , EvalFormula ); //create new column for CTM Isc
	New Column( "CTM FF", Numeric, Continuous, Formula( :Fill_Factor - :Cell_FF ) , EvalFormula ); //create new column for CTM FF
	New Column( "Ncell delta", Continuous, Nominal, Formula( (:Cell_NCell*100) - (:CellEff/100) ) , EvalFormula ); //create new column for Ncell delta
	Column( "CellEff" ) << data type( numeric ) << modeling type( nominal );
	Column( "Lamp1" ) << hide( 1 );
	Column( "Lamp2" ) << hide( 1 );
	Column( "Lamp3" ) << hide( 1 );
	Column( "Lamp4" ) << hide( 1 );
	Column( "Lamp5" ) << hide( 1 );
	Column( "Lamp6" ) << hide( 1 );
If(GT==2,
	dt << Tabulate(
	Show Control Panel( 0 ),
	Set Format( N( 9, "Best" ) ),
	Add Table(
		Column Table(
			Analysis Columns(
				:Pmp,
				:Voc,
				:Isc,
				:Fill_Factor,
				:Cell_Voc,
				:Cell_Isc,
				:Cell_FF,
				:Cell_NCell,
				:CTM Voc,
				:CTM Isc,
				:CTM FF,
				:Ncell delta,
				:Rs
			Statistics( Mean )
		Column Table( Statistics ( N ) ),
		Row Table( Grouping Columns( :CellPaste,:Cell_Line,:CellEff,:CellDate) )
If(GT==2,
Variability Chart(SendToByGroup({:Line == "L6A"}), Y(:Pmp, :Voc, :Isc, :Vmpp, :Impp, :Fill_Factor), SendToByGroup({:Line == "L6A"}, Y(:Pmp)), SendToByGroup({:Line == "L6A", Platform Index(2)}, Y(:Voc)), SendToByGroup({:Line == "L6A", Platform Index(3)}, Y(:Isc)), SendToByGroup({:Line == "L6A", Platform Index(4)}, Y(:Vmpp)), SendToByGroup({:Line == "L6A", Platform Index(5)}, Y(:Impp)), SendToByGroup({:Line == "L6A", Platform Index(6)}, Y(:Fill_Factor)), SendToByGroup({:Line == "L6B"}, Y(:Pmp)), SendToByGroup({:Line == "L6B", Platform Index(2)}, Y(:Voc)), SendToByGroup({:Line == "L6B", Platform Index(3)}, Y(:Isc)), SendToByGroup({:Line == "L6B", Platform Index(4)}, Y(:Vmpp)), SendToByGroup({:Line == "L6B", Platform Index(5)}, Y(:Impp)), SendToByGroup({:Line == "L6B", Platform Index(6)}, Y(:Fill_Factor)), X(:CellEff, :Day, :CellDay), Max Iter(100), Conv Limit(0.00000001), Number Integration Abscissas(128), Number Function Evals(65536), Analysis Type("Choose best analysis (EMS REML Bayesian)"), Show Range Bars(0), Connect Cell Means(1), Std Dev Chart(0), Points Jittered(1), Show Box Plots(1), Mean Diamonds(1), By(:Line), SendToByGroup({:Line == "L6A"}, SendToReport(Dispatch({"Variability Gauge Line=L6A", "Variability Chart for Pmp"}, "Variability Chart", FrameBox, {DispatchSeg(BoxPlotSeg(1), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(2), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(3), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(4), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(5), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(6), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(7), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(8), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(9), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(10), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(11), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(12), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(13), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(14), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(15), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(16), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(17), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(18), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(19), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(20), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(21), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(22), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(23), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(24), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(25), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(26), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(27), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(28), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(29), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(30), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(31), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(32), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(33), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(34), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(35), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(36), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(37), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(38), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(39), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(40), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(41), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(42), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(43), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(44), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(45), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(46), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(47), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(48), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(49), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(50), {Box Type("Outlier"), Line Color("Red")})}))), SendToByGroup({:Line == "L6A", Platform Index(2)}, SendToReport(Dispatch({"Variability Gauge Line=L6A", "Variability Chart for Voc"}, "Variability Chart", FrameBox, {DispatchSeg(BoxPlotSeg(1), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(2), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(3), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(4), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(5), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(6), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(7), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(8), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(9), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(10), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(11), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(12), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(13), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(14), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(15), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(16), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(17), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(18), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(19), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(20), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(21), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(22), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(23), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(24), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(25), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(26), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(27), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(28), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(29), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(30), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(31), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(32), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(33), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(34), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(35), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(36), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(37), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(38), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(39), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(40), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(41), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(42), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(43), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(44), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(45), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(46), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(47), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(48), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(49), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(50), {Box Type("Outlier"), Line Color("Red")})}))), SendToByGroup({:Line == "L6A", Platform Index(3)}, SendToReport(Dispatch({"Variability Gauge Line=L6A", "Variability Chart for Isc"}, "Variability Chart", FrameBox, {DispatchSeg(BoxPlotSeg(1), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(2), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(3), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(4), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(5), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(6), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(7), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(8), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(9), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(10), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(11), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(12), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(13), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(14), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(15), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(16), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(17), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(18), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(19), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(20), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(21), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(22), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(23), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(24), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(25), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(26), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(27), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(28), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(29), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(30), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(31), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(32), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(33), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(34), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(35), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(36), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(37), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(38), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(39), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(40), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(41), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(42), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(43), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(44), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(45), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(46), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(47), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(48), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(49), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(50), {Box Type("Outlier"), Line Color("Red")})}))), SendToByGroup({:Line == "L6A", Platform Index(4)}, SendToReport(Dispatch({"Variability Gauge Line=L6A", "Variability Chart for Vmpp"}, "Variability Chart", FrameBox, {DispatchSeg(BoxPlotSeg(1), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(2), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(3), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(4), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(5), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(6), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(7), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(8), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(9), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(10), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(11), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(12), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(13), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(14), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(15), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(16), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(17), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(18), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(19), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(20), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(21), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(22), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(23), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(24), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(25), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(26), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(27), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(28), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(29), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(30), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(31), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(32), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(33), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(34), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(35), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(36), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(37), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(38), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(39), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(40), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(41), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(42), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(43), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(44), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(45), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(46), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(47), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(48), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(49), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(50), {Box Type("Outlier"), Line Color("Red")})}))), SendToByGroup({:Line == "L6A", Platform Index(5)}, SendToReport(Dispatch({"Variability Gauge Line=L6A", "Variability Chart for Impp"}, "Variability Chart", FrameBox, {DispatchSeg(BoxPlotSeg(1), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(2), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(3), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(4), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(5), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(6), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(7), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(8), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(9), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(10), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(11), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(12), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(13), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(14), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(15), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(16), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(17), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(18), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(19), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(20), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(21), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(22), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(23), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(24), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(25), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(26), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(27), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(28), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(29), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(30), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(31), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(32), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(33), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(34), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(35), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(36), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(37), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(38), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(39), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(40), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(41), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(42), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(43), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(44), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(45), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(46), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(47), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(48), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(49), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(50), {Box Type("Outlier"), Line Color("Red")})}))), SendToByGroup({:Line == "L6A", Platform Index(6)}, SendToReport(Dispatch({"Variability Gauge Line=L6A", "Variability Chart for Fill_Factor"}, "Variability Chart", FrameBox, {DispatchSeg(BoxPlotSeg(1), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(2), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(3), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(4), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(5), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(6), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(7), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(8), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(9), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(10), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(11), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(12), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(13), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(14), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(15), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(16), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(17), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(18), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(19), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(20), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(21), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(22), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(23), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(24), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(25), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(26), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(27), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(28), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(29), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(30), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(31), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(32), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(33), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(34), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(35), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(36), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(37), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(38), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(39), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(40), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(41), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(42), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(43), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(44), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(45), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(46), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(47), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(48), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(49), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(50), {Box Type("Outlier"), Line Color("Red")})}))), SendToByGroup({:Line == "L6B"}, SendToReport(Dispatch({"Variability Gauge Line=L6B", "Variability Chart for Pmp"}, "Variability Chart", FrameBox, {DispatchSeg(BoxPlotSeg(1), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(2), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(3), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(4), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(5), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(6), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(7), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(8), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(9), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(10), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(11), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(12), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(13), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(14), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(15), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(16), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(17), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(18), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(19), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(20), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(21), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(22), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(23), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(24), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(25), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(26), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(27), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(28), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(29), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(30), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(31), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(32), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(33), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(34), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(35), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(36), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(37), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(38), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(39), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(40), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(41), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(42), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(43), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(44), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(45), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(46), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(47), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(48), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(49), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(50), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(51), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(52), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(53), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(54), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(55), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(56), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(57), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(58), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(59), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(60), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(61), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(62), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(63), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(64), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(65), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(66), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(67), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(68), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(69), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(70), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(71), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(72), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(73), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(74), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(75), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(76), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(77), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(78), {Box Type("Outlier"), Line Color("Red")})}))), SendToByGroup({:Line == "L6B", Platform Index(2)}, SendToReport(Dispatch({"Variability Gauge Line=L6B", "Variability Chart for Voc"}, "Variability Chart", FrameBox, {DispatchSeg(BoxPlotSeg(1), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(2), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(3), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(4), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(5), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(6), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(7), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(8), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(9), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(10), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(11), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(12), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(13), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(14), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(15), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(16), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(17), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(18), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(19), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(20), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(21), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(22), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(23), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(24), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(25), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(26), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(27), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(28), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(29), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(30), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(31), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(32), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(33), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(34), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(35), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(36), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(37), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(38), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(39), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(40), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(41), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(42), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(43), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(44), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(45), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(46), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(47), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(48), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(49), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(50), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(51), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(52), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(53), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(54), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(55), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(56), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(57), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(58), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(59), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(60), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(61), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(62), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(63), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(64), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(65), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(66), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(67), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(68), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(69), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(70), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(71), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(72), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(73), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(74), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(75), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(76), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(77), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(78), {Box Type("Outlier"), Line Color("Red")})}))), SendToByGroup({:Line == "L6B", Platform Index(3)}, SendToReport(Dispatch({"Variability Gauge Line=L6B", "Variability Chart for Isc"}, "Variability Chart", FrameBox, {DispatchSeg(BoxPlotSeg(1), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(2), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(3), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(4), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(5), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(6), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(7), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(8), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(9), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(10), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(11), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(12), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(13), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(14), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(15), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(16), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(17), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(18), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(19), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(20), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(21), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(22), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(23), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(24), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(25), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(26), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(27), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(28), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(29), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(30), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(31), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(32), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(33), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(34), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(35), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(36), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(37), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(38), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(39), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(40), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(41), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(42), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(43), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(44), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(45), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(46), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(47), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(48), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(49), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(50), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(51), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(52), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(53), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(54), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(55), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(56), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(57), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(58), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(59), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(60), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(61), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(62), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(63), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(64), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(65), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(66), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(67), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(68), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(69), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(70), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(71), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(72), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(73), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(74), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(75), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(76), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(77), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(78), {Box Type("Outlier"), Line Color("Red")})}))), SendToByGroup({:Line == "L6B", Platform Index(4)}, SendToReport(Dispatch({"Variability Gauge Line=L6B", "Variability Chart for Vmpp"}, "Variability Chart", FrameBox, {DispatchSeg(BoxPlotSeg(1), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(2), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(3), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(4), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(5), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(6), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(7), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(8), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(9), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(10), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(11), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(12), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(13), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(14), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(15), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(16), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(17), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(18), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(19), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(20), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(21), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(22), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(23), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(24), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(25), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(26), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(27), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(28), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(29), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(30), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(31), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(32), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(33), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(34), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(35), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(36), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(37), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(38), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(39), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(40), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(41), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(42), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(43), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(44), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(45), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(46), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(47), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(48), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(49), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(50), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(51), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(52), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(53), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(54), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(55), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(56), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(57), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(58), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(59), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(60), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(61), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(62), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(63), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(64), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(65), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(66), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(67), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(68), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(69), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(70), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(71), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(72), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(73), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(74), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(75), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(76), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(77), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(78), {Box Type("Outlier"), Line Color("Red")})}))), SendToByGroup({:Line == "L6B", Platform Index(5)}, SendToReport(Dispatch({"Variability Gauge Line=L6B", "Variability Chart for Impp"}, "Variability Chart", FrameBox, {DispatchSeg(BoxPlotSeg(1), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(2), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(3), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(4), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(5), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(6), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(7), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(8), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(9), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(10), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(11), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(12), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(13), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(14), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(15), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(16), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(17), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(18), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(19), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(20), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(21), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(22), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(23), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(24), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(25), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(26), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(27), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(28), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(29), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(30), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(31), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(32), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(33), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(34), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(35), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(36), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(37), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(38), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(39), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(40), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(41), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(42), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(43), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(44), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(45), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(46), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(47), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(48), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(49), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(50), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(51), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(52), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(53), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(54), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(55), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(56), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(57), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(58), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(59), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(60), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(61), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(62), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(63), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(64), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(65), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(66), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(67), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(68), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(69), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(70), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(71), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(72), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(73), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(74), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(75), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(76), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(77), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(78), {Box Type("Outlier"), Line Color("Red")})}))), SendToByGroup({:Line == "L6B", Platform Index(6)}, SendToReport(Dispatch({"Variability Gauge Line=L6B", "Variability Chart for Fill_Factor"}, "Variability Chart", FrameBox, {DispatchSeg(BoxPlotSeg(1), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(2), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(3), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(4), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(5), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(6), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(7), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(8), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(9), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(10), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(11), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(12), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(13), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(14), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(15), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(16), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(17), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(18), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(19), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(20), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(21), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(22), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(23), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(24), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(25), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(26), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(27), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(28), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(29), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(30), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(31), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(32), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(33), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(34), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(35), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(36), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(37), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(38), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(39), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(40), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(41), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(42), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(43), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(44), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(45), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(46), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(47), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(48), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(49), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(50), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(51), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(52), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(53), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(54), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(55), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(56), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(57), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(58), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(59), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(60), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(61), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(62), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(63), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(64), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(65), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(66), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(67), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(68), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(69), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(70), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(71), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(72), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(73), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(74), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(75), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(76), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(77), {Box Type("Outlier"), Line Color("Red")}), DispatchSeg(BoxPlotSeg(78), {Box Type("Outlier"), Line Color("Red")})}))))
gzmorgan0
Re: Substituting a direct data type into WHERE clause
Ding,
It would be useful if you attached the error message seen in the log. I assume that the query is not extracting data?
If that is the case, then either the connection string is incorrect (or you have not installed the proper ODBC drivers) or the query string is incorrect.  BTW, I suggest you edit your post to remove anything that should not be shared(maybe WSID, just make WSID=).
You did not mention if you have been able to run this script for CTI_Date. If this script runs for CTI_Date, then the problem is with your query string (SQL1). If it does not run, then you know the connection string needs to change or you need to load or define database drivers. For problems with the connection string, you need to contact the peope that manage the database you are trying to access.
If the script runs for CTI_Date, here are a couple of potential sources of error for you query string:
  • The data base table you are querying (from [dbo].[v_ModulePowerCellCTI]) dbo is the database name and v_ModulePowerCellCTI is a specific database table.  Is this the correct table? Is there another table called v_ModulePowerCellPalletized ?
  • If the table is correct,  is the name correct?  Since it was CTI_Date, should the field name be Palletized_Date? Check for the correct name.
  • If the name is correct, check the format of PalletizedDate. You would think that in the same database all fields have the same naming structure (e.g. CTI_Date and Palletized_Date) and the same format. But I have worked on large databases where 3 different datetime fields had different formats.
 Yuo did not mention which version of JMP you are using.  You can check out whether you can connect to a database, get the table names and get the column name and format interactively.  From the Help menu, select Books and select Using JMP.  Search for  "Connect to a SQL Database". If you have JMP 12 or higher, there is a nice GUI to connect, get a list of tables in the database, select the table and see all the field (column) names and the dat types.
The book walk you through each step. According to your script you should have a driver in the machine data source called SQL.  This interface allow you to check for connectivity, get alist of tables, look at each table's columns, etc.
This is all I have unless you have more details about the error you are getting, or ifthis runs for CTI_Date.
Good Luck!
Ding
Thanks for the feedback.
The issue when I did the replacement of CTI_Date and run the script, was that the JMP software would be completely unresponsive. It will then need to be restarted for it to be functional again.
I checked the differences between CTI_Date and PalletizedDate from dbo, the only differences is the IS_NULLABLE (CTI_Date = YES , PalletizedDate = NO). Would this have an effect? The date format is all the same.
gzmorgan0
You did not state if the script runs for you with CTI_Date.
