BookmarkSubscribeRSS Feed
StringColBox Header Height - how to stop it from auto-expanding?
djhanson
Jun 23, 2011
I'm doing a stringcolbox(myTitle,{"thing1","thing2","thing3"};
where myTitle is a variable string I've created before.
Problem is:
myTitle = if this exceeds a certain number of characters in length (not many either), it expands the whole header height up like double in size.  How to stop this from happening?  I looked in the Properties and I'm not also seeing a way to control the header height.  Is there another way?  DJ
e.g.
myTitle ="Param";  this is ok
myTitle="Parm B Big Widget X-Bar"; this or something larger or spaces blows up the header height unnecessarily (even when I set a large width for this column)
1 REPLY
djhanson
Jun 23, 2011
Might add this is in JMP 12.2
